Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 04-09-2012, 01:28 PM   #55
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
Meron sa US ng headers approx 800U$
SRI and CAI ako will go back to stock, stock sucks pero nothing sucks like a cone filter.
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 04-10-2012, 01:12 AM   #56
Onads
Onads's Avatar
Drives: Vios/Yaris
Haha.. Yup Iba pa din talaga pag open filter ka. Maganda din kung modify yung headers and pipings. Basic modification Stage 1. Intake/Headers/Exhaust. Guarantee laki ng gains sa HP. Kita mo ang difference.
800$ Mahal headers palang yan.. Stainless naman kasi. Kung pede lang mag pa ship from Phil to KSA ng headers and pipings. hay... Sa atin kasi sa 7-10K PHP buo na ang stage 1 mo.
Onads is offline   Reply With Quote
Old 04-11-2012, 12:31 AM   #57
Marlboro
Marlboro's Avatar
Drives: Yaris
Regarding stage 1 mods maglalaro lang cya sa 5 to 8 hp di masyado ramdam kung talagang gusto mo lumakas hp ng oto no choice but magpa turbo more or less nasa 60 to 70 percent ang itatataas ng hp ng car mo. Pero ok ang stage 1 pang porma :)
Marlboro is offline   Reply With Quote
Old 04-11-2012, 03:20 AM   #58
Just for clarification, the Yaris only has one header, so it's not headers.
Full bolt ons will get you about 10 hp at most without a tune. A tune is what will get you the most power out of your mods.
Old 04-11-2012, 03:22 AM   #59
Probably the best performance mod would be very light weight rims and tires. I say this because everything improves, acceleration, braking, cornering, and gas mileage.
Old 04-11-2012, 03:28 AM   #60
My Tagalog reading skills is horrible (can only understand it when I'm spoken to), but a drop in K&N filter will not give you any performance increase. It's still in the same restrictive intake box with the same carbon trap filter. It's usually only good for being a one time purchase filter that can be reused.
As for water, as long as you don't drive through a flooded area, you should be good. You can also get a hydroshield to prevent any drops of water from being sucked in (won't protect you if you try to drive through a flooded road). Mine works great. I don't bother to "bag" my filter when I wash my car.
Old 04-11-2012, 06:33 AM   #61
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
1.3L and 1.5L is different
in addition to above..
The header for 1.3L 2nz-fe yaris is not compatible with the one from US. US header are for 1.5L 1nz-fe in majority.
Unless, you have the yaris 1.5L sporty edition here in ksa, then its a bolt-on.
I don't know why in these country, they used to sell small displacement engines cars eventhough the gas is cheaper than water
ricepower is offline   Reply With Quote
Old 04-11-2012, 02:22 PM   #62
charlieXX
Corporate Slave
charlieXX's Avatar
@Kaotic can you share the website where you got the hydroshield K&N
Old 04-11-2012, 03:26 PM   #63
Find your filters measurements and look up the part number here: http://www.knfilters.com/search/wrap.aspx
Be sure you are looking under drycharger and not precharger filters/wraps.
Then you can find that K&N part number on Amazon: http://www.amazon.com/s/ref=nb_sb_ss...ry%2Caps%2C302
Old 04-12-2012, 01:17 AM   #64
mikedizzle
Drives: 2010 toyota yaris sedan
what kind of intake you have?
mikedizzle is offline   Reply With Quote
Old 04-12-2012, 01:28 AM   #65
Me? I have the K&N SRI (Typhoon). I just wrapped it with some heat reflective material since the pipe is black and made of aluminum (which gets heat soaked easily).
The pipe wrapped:
Old 04-12-2012, 01:30 AM   #66
Yes, I did notice a difference if how hot it feels. Before the wrap, touching the pipe was sometimes unbearable. I can now keep my hand on the pipe after I wrapped it.
performance-wise? Not really sure since I've always had HEAVY rims. lol
Old 04-12-2012, 02:25 AM   #67
barebonedvitz
return of the comeback
barebonedvitz's Avatar
Drives: white '08LB..very nice,i like
i got mine from http://www.outerwearsracing.com/ They're all pretty much the same thing.. just branded differently.. got mine from 10yrs ago for my civic and still works great!
Everything will be ok in the end... if it's not ok, it's not the end.
93 Civic Si- SC/B18B1 - street beast
07 Red/BlackTop Yaris LB - died in a sandwich in 2010@168K.
08 White Yaris LB - daily beatnut...round 2!
barebonedvitz is offline   Reply With Quote
Old 04-12-2012, 02:34 AM   #68
barebonedvitz
what's great about these guys is that they can make custom wraps!
I believe this will be beneficial for our radiators, evaporators and for some, intercoolers... so those poor bugs don't get stuck in between the fins and die a horrid death...
Old 04-18-2012, 10:15 AM   #69
syntax
syntax's Avatar
@ kaotic thanks for the clarifications, im sure we take notes on this one
Old 04-24-2012, 02:53 AM   #70
atvtorres
Drives: yaris yx 2009
Tanong lang po kung pwede to sa yaris 1.3L(2nzfe)? Thanks!
http://www.ebay.com/itm/290400046694...#ht_5655wt_905
atvtorres is offline   Reply With Quote
Old 04-24-2012, 03:25 AM   #71
ricepower
ricepower's Avatar
YES. It's bolt-on or plug n play to our 1.3L.
PM kiel12 for the experiences.
Old 04-24-2012, 06:07 AM   #72
atvtorres
Thanks sa info!
Any Aftermarket Intakes Yet?!?!?!?! silverRS Performance Modifications 120 12-07-2011 06:44 PM
Weapon-r sheet metal intakes 1/2 off (almost) H3LlIoN Forced Induction Forum 5 11-27-2010 12:21 AM
aFe intakes in stock! cali yaris Micro Image 66 02-11-2010 04:58 PM
air intakes? SLIK4 General Yaris / Vitz Discussion 16 05-21-2007 09:34 PM
