Old 01-20-2012, 10:17 AM   #55
Vic-2NZFE
Vic-2NZFE's Avatar
Drives: Yaris 2NZFE
any word on this? how did it go?
It's a Vitz!
Vic-2NZFE is offline   Reply With Quote
Old 01-20-2012, 11:33 PM   #56
docB
Drives: '09 Yaris Sedan
i guess this isn't for street cars? How do you reprogram the speedo?
doc
docB is offline   Reply With Quote
Old 01-21-2012, 12:01 AM   #57
Sure it is -- but it depends on your tolerance for high revs on the freeway. Otherwise, it improves the Yaris' performance value a LOT.
You don't. As far as I can tell, it didn't change that. Aren't the speed sensors at the wheels?
I haven't drag raced again since then, sorry.
Old 01-21-2012, 09:31 AM   #58
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
The output for the speed sensor is read off of the final drive assembly. But you aren't spinning the FD any faster because your wheels aren't turning any faster at the same speed. It's all the other gear before the FD that change speed. (I hope that makes sense to you all)
Old 01-21-2012, 11:15 AM   #59
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
And I'm working on a solution for this. If you're pulling all the gears off the output shaft anyway, you might as well replace the 5th gear set with the taller overdrive from the '03-ish Matrix/Vibe/Corolla. That drops your 70 mph revs from about 3600 down to 3200. For reference, the stock trans does about 3500@80 and 3000@70.
You can get an idea of how it would sound by finding a "closed road course" and a "professional driver" to achieve that speed.
I think the newer models use a wheel/axle sensor instead of the internal speedo gear, but the principle is the same. Changing the internal gear ratios only modifies the torque delivered at a given wheel RPM. The trade off is that the transmission input RPMs (engine RPMs) have to change to make the same output speed.
Old 01-21-2012, 11:31 AM   #60
This is correct for Yaris with ABS. For them the speedometer is fed from the ABS ECU, rather than from the transmission.
Old 01-21-2012, 07:08 PM   #61
Where is the ABS Ecu?
Old 03-30-2012, 09:18 PM   #62
Jason@SportsCar
Update: we now have a complete trans with the Kaaz gear set from Micro Image, going to be installing it this weekend.
In addition to a little bit of machine work being needed on the 3rd and 4th input gears (which Kaaz will do before shipping the gears out) you will need a new 3rd and 4th synchro, and one new synchro sleeve.
These are OE Toyota parts (I am told Celica parts):
sychro sleeve 33364-20051
3rd 33368-20061
4th 33368-20071
Old 03-31-2012, 01:05 AM   #63
^ NICE. Now go race.
Old 05-04-2012, 02:32 PM   #64
Jason@SportsCar
The close-ratio trans setup works awesome.
Old 05-04-2012, 02:39 PM   #65
Bluevitz-rs
video? :)
Old 05-04-2012, 02:40 PM   #66
Jason@SportsCar
video? :)
http://www.youtube.com/watch?v=LjOtkt34gJM
Old 05-04-2012, 02:49 PM   #67
Bluevitz-rs
haha, I found it like 10 seconds after posting in the other thread LOL.
Old 05-04-2012, 03:01 PM   #68
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
nice that car is very noisy .. i like it :D
Old 05-04-2012, 07:34 PM   #69
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
wow, i see you passed at least a mustang, couldn't recognize any of the other cars. Kicking butt and taking names.
Colin Chapman disciple
Old 05-04-2012, 08:37 PM   #70
CrankyOldMan
Yaris! It's a (RACE) car!
Old 05-04-2012, 11:51 PM   #71
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
impressive..
-Derrick-
Old 05-05-2012, 12:36 AM   #72
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Perhaps if the owner of YW actually participated a bit I could have a "like" button to use like so many other modern forums, but alas all I can do is quote and +1.
I got $50 to test drive Cutie Pie #2 Off-topic / Other Cars / Everything else Discussions 6 02-23-2009 10:51 AM
mid pipe swap shinlee Performance Modifications 0 02-09-2009 11:44 PM
final drive rx100 Performance Modifications 2 08-21-2007 02:26 AM
Longest Test Drive? lostmind General Yaris / Vitz Discussion 4 05-31-2007 06:20 PM
Official bitch about gas price thread flint_mica_manual General Yaris / Vitz Discussion 61 05-24-2007 10:53 PM
