Old 03-20-2007, 10:36 AM   #1
mrrock
Drives: yaris 2dr hatch
POWER WINDOW POWER SOURCE IN DOOR PANEL?
I have the door panel off and see that there is round unused 4 prong plug that is not used on the upper front part of the door panel. Has anyone used this plug or wires to install the power window kits. Is it just installing the fuse so there will be power to these wires.
I've check several of the threads and don't see to find anything
mrrock is offline   Reply With Quote
Old 03-20-2007, 11:14 AM   #2
ChinoCharles
Drives: LB
Why don't you just wire it to the fuse box under the driver's side dash?
Old 03-21-2007, 01:05 AM   #3
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
ya really
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 03-21-2007, 02:10 PM   #4
asmodai650
asmodai650's Avatar
Drives: 2007 Yaris Sedan Pacific Blue
according to the manual I just downloaded, that is the plug for the power package, not just the windows. All of the following hook into it, and not sure if aftermarket kits will eventually use this or not:
G 1 Power Window Master SW
G 2 Outer Rear View Mirror (LH)
G 4 Power Window Regulator Motor (Front LH)
G 5 Door Lock Assembly (Driver’s Side)
G 6 Speaker (Front Door LH)
G 7 Door Lock Control SW (Driver’s Side)
asmodai650 is offline   Reply With Quote
Old 03-21-2007, 06:25 PM   #5
mrrock
thanks for actually answering the question. why run new wires if the already exist. is the manual you downloaded the info on this forum?
thanks in advance
Old 03-21-2007, 07:27 PM   #6
asmodai650
asmodai650's Avatar
Here you go: http://www.etimago.com/yaris/repairmanual/
You can download whichever section you need, or do as I did and dl the whole thing, and burn it to a cd. Just don't buy it off ebay, get it here instead.
Questions and advice required about power upgrading(windows & locks) W.A.S.P DIY / Maintenance / Service 10 07-22-2009 03:59 AM
Need Help - Electrical (finding Power) Ayka DIY / Maintenance / Service 7 10-12-2006 12:51 PM
