Free Mustache Rides
need to tighten subframe..?
my car creaks when turning the wheel to the right. after reading multiple threads, it seems the creak sound by my front right tire may be caused to loose subframe bolts. I'll get under the car tomorrow, but before i do so does anybody know what size bolts they are or if i could possibly ruin my car by just making them as tight as possible?
if it isn't the subframe i guess ill check the sway bar bushings. thanks in advance
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
Check for the TSB regarding the subframe bolts. Toyota was replacing some however mine was past warranty so I bought the two bolts in question. Had a shop remove the broken one (using an air chisel to turn it out) and replace both. Cost me under $120.00 compared to Toyota's >$700.00 quote, which included replacement of some subframe components and a complicated process.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| How much with Air Impact Wrench to tighten lug nuts | Shinare | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 12-16-2010 04:58 PM |
| Tighten bolts to factory specs? | marlondog | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 10-19-2010 05:18 PM |
| Tighten e-brake? | Snyprwlf47 | DIY / Maintenance / Service | 6 | 01-20-2009 05:44 AM |
