Old 06-20-2012, 12:28 AM   #1
Hershey
Canada Toyota genuine motor oil viscosity application chart : 0w-20 approved for ...
Yaris from 2006 > 2012 . Got confirmation from Toyota of Canada that this chart is authentic . Here's the chart , http://pdfcast.org/pdf/toyota-oil-recommendation . So why would the 0w-20 be fine in Canada and not the States ? Some regions here have very similar climate as Canada . The email says the 0w-20 and 5w-20 are safe for the 1.5 ltr. , but the use of any other weight than the 5w-30 should be discussed with a dealer ( service center ) . Toyota doesn't make it easy when it comes to oils . The 2012 Prius "C" is stated 0w-20 and that is very close relative of the Yaris 1.5 .
Old 06-20-2012, 11:44 AM   #2
TOLMACH
Drives: soarer
i would not use 20 oil even in ca
using 5 w 30
Old 06-20-2012, 01:17 PM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
The USA is more litigious in the US than Canada. At this point Toyota NA is letting the lawyers make all the calls for the US.
Colin Chapman disciple
Old 06-22-2012, 12:49 PM   #4
YodaBird
Drives: Gray
Should I buy this Toyota Motor oil or is there another type that I should buy that is just as good if not better ?
YodaBird is offline   Reply With Quote
Old 06-22-2012, 04:15 PM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
That will become a loaded question pretty quickly. IMHO perform a search and read what others have said too many times to to count. I use only AMSOIL products in my vehicles as of last year and have no complaints. The exception to this is that I used their motor oil in my previous engine for a little over 40k and the inside of my motor looks super clean as I have dismantled it.
Old 06-22-2012, 07:01 PM   #6
YodaBird
Drives: Gray
I should follow your advice, and you used AMSOIL products on Yaris as well, I assume ? Any other synthetic motor oil, recommendations ?
Old 06-23-2012, 12:28 AM   #7
Hershey
Toyota synthetic oils are good quality . Usually MOBIL 1 with different additives specified by Toyota . Here's an example , but a conventional oils . These are virgin oil analysises of Toyota 5w-30 (SN) http://www.pqiamerica.com/Janaury%20...lts/toyota.htm and Mobil Super 5000 5w-30 (SN) http://www.pqiamerica.com/ExxonMobilSuper5000.htm . You'll see some resemblance . The additive pack may be different ( better? ) than those for the U.S..
Old 06-23-2012, 09:35 AM   #8
craigq
Drives: '07 Yaris, '12 GLI
FWIW Toyota 0W20 shows decent UOA's on http://www.bobistheoilguy.com.
Most oils do, really. Unless you're doing long oil change intervals, or your engine has a known issue (i.e. PCV systems on some cars are terrible, small oil passages near exhaust etc) or it's direct injected, or direct injected and turbocharged, most of the major brand oils do quite well, yes even conventional.
craigq is offline   Reply With Quote
Genuine Toyota Hitch for Yaris now available in Canada voodoo22 DIY / Maintenance / Service 8 04-22-2014 08:50 AM
Yaris In Forza 3 whooppee777 Off-topic / Other Cars / Everything else Discussions 61 04-03-2010 05:36 PM
Is Genuine Toyota Motor Oil better? curtqn DIY / Maintenance / Service 12 10-13-2009 09:46 PM
Petition to Toyota Canada for the Turbo! Doc Zaius Canada 5 02-05-2007 07:32 PM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 04:16 AM
