Old 07-07-2012, 04:45 AM   #1
Fehrain
Drives: 2009 Toyota Yaris 5dr HB
Questions regarding lowering.
Hi, I'm new to this forum, and just recently decided to started modding my 2009 Yaris 4 door Hatchback.
Now for the questions:
I just recently purchased and installed Sparco Assetto Gara(bronze) on my car. I'm looking to lower my car with Tein S-techs and Tokico HP Blues. Will I rub/poke with those? And will I need a camber kit or roll my fenders?
Other info:
Wheels have +30 offset 15x6.5 and 185/60 R15 for all four tires.
Also of note, I'm new at this stuff but I want to learn, so any explanations regarding terminology and reasons for things would greatly help!
Fehrain is offline   Reply With Quote
Old 07-07-2012, 06:02 AM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Welcome!
That's about a 1" drop, right? I think you'll do fine.
You may want to think about adding just a little bit of camber just in case you get too close to the fender, but it's an easy/cheap fix.
Old 07-07-2012, 08:37 AM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've got blues/s-techs also, and it's about a 2" drop. I'm running 205/50R15's on stock wheels and have had no tire clearance issues so far. I did run into a ground clearance issue at the car wash the other day though...
You can use the "size comparer" on www.rimsntires.com to see what the difference is between two different wheel/tire setups.
Old 07-07-2012, 09:58 AM   #4
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
You should be more than fine with that setup.
comparison to stock:
http://www.1010tires.com/WheelOffsetCalculator.asp
Old 07-07-2012, 10:48 AM   #5
yPod09
All black everything.
yPod09's Avatar
Drives: '09 5dr All black.
Welcome to the forum! What color is your car?
I just did the exact same set-up on the exact same car, same shocks/struts, same springs, same tire size, with a +38 offset. Everyone swore to me that there would be no rubbing, this has NOT been the case. On curvy mountain roads and very spirited driving, my front tires rub quite a bit, especially the left.
I love the set-up otherwise, but that is a little frustrating. I may add a degree of camber in the front, see if that helps.
Just to let you know.
p.s. I'm new to the world of car mods and don't totally understand offset, but I think it means that your wheels would stick out further than mine. Which will look GREAT, but might rub more.
yPod09 is offline   Reply With Quote
Old 07-07-2012, 12:17 PM   #6
Fehrain
Thanks for the replies! Haha my car is Blazing blue metallic. I'm still not sure if I'm going to get the springs/shocks right now, but that's what I plan to do. I don't really have to worry about curvy roads since I'm in houston XD and it's all flat/straight roads lol. Makes for boring drives though >.> Potholes on the other hand..... all over the place. If I do get the set up, I probably will add some camber regardless just to be safe.
Old 07-07-2012, 12:28 PM   #7
1.5
Form>Function
1.5's Avatar
a hint of camber, -.5 to -1.5 is going to really help with handling and you should see almost no camber wear.
Old 07-07-2012, 01:12 PM   #8
^ almost no tread wear.
Old 07-07-2012, 01:20 PM   #9
1.5
Form>Function
1.5's Avatar
Yea that's what I meant lol
Old 07-08-2012, 12:58 PM   #10
Fehrain
Thanks for the help guys! Now I just need to get the stuff lol.
Old 07-14-2012, 07:06 PM   #11
nimuntak
Nikki Alanna
Drives: 08 Meteorite Metallic Hatch
Im selling my coil overs from my yaris, they dropped my car about 4-5 inches. I bought them brand new, but I'm selling my car and have no need for the coils anymore.
I'm asking about 1000-1100, as i did buy them for 1300.
Message me if interested!
nimuntak is offline   Reply With Quote
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
Lowering or Not? chrisj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-06-2010 02:34 PM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
Lowering Springs - Questions ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 01-10-2007 08:21 AM
