Old 07-09-2012, 11:20 AM   #2053
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I hate drilling into metal...
― Thomas Paine
Old 07-09-2012, 10:23 PM   #2054
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Me too! I'm going to confirm that in a few minutes!
D.
CLA 250, 4MATIC
Old 07-10-2012, 01:06 AM   #2055
derickveliz2
Originally Posted by 07typeS View Post
And if you do try the sawzall, please get it on video!!!! haha
I did it! I did it!
Video1:*It was so easy that I took my phone for a video!
Video 2: Without holding my cell phone for video I could probably have done it in less than half of the time..
D.
CLA 250, 4MATIC
Old 07-10-2012, 01:23 AM   #2056
derickveliz2
OK, this was so EASY, just like a hot knife on butter! best $15 bucks spent.
Now I have left tweeter as far forward and far to the left I possible can! I gain 5 inches and that's a lot! the distance from my left ear to tweeter now is 48" it used to be 43".
Stage is wider and deeper already!
Probably 5 inches sound meaningless, but you should hear the difference that it makes.
Picture 1: the a-pillar after cutting the metal
Picture 2: Tweeter in place! NICE! I'm happy.
D.
CLA 250, 4MATIC
Old 07-10-2012, 06:41 AM   #2057
sickpuppy1
Drives: 2010 Yaris Sedan
What about the aiming? Looks like its down at the dash....
Old 07-10-2012, 09:49 AM   #2058
sqcomp
Roadrunner Jr.
sqcomp's Avatar
The aiming axis at that point will only have a minor effect. The gain Derick has from physical location is going to override the angle for the most part. What I'm going to be interested to see is how the mounting is integrated with the a pillar.
I see that mount is deep...really deep in there. What say you Derick? This may be a good experiment for horn loading...
― Thomas Paine
Old 07-10-2012, 09:52 AM   #2059
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Sand down those edges on that metal, run that wire...are you going to surround the mounting hole with some deadening to reduce resonances? How's the tweeter going to be mounted?
― Thomas Paine
Old 07-11-2012, 02:05 PM   #2060
derickveliz2
Yeah me too! I'm thinking about cutting a big section (hole) in the lower part of the a-pillar and build up a big open horn shape from the tweeter's base to the opening of the a-pillar, I'm not sure how to accomplish that, but I'll dig into it.
D.
Yes will deaden the area, I will use a thin sheet of wood/balsa wood or even MLV as baffle into the metal.
D.
CLA 250, 4MATIC
Old 07-11-2012, 08:48 PM   #2061
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Baffling into the metal...I wish I could be out there with you to help. I think between the two of us we could make this happen REALLY quickly.
*sigh*
Using some substrate you can drill into using the L1v2's mounting holes. I'm thinking even a 1/4" pan head would be fine and not kick too far into the metal depending on the thickness of the substrate.
I'd say make a couple rings out of balsa that are juuuuusssst slightly larger than the outer diameter of the tweeter and then reverse the technique we've used to make the original pillars. Build in instead of out.
Thoughts?
― Thomas Paine
Old 07-11-2012, 10:38 PM   #2062
derickveliz2
........and then reverse the technique we've used to make the original pillars. Build in instead of out.
Thoughts?
You read my mind!
D.
CLA 250, 4MATIC
Old 07-11-2012, 11:24 PM   #2063
sickpuppy1
Kind of a speaker mounted in a funnel. Interesting.....Hey, what about using a funnel! lol
Old 07-11-2012, 11:26 PM   #2064
sickpuppy1
By angleing the cut on the material you could still aim it a bit if needed. If nothing else it would be a cheap way to experiment.
Old 07-11-2012, 11:27 PM   #2065
sickpuppy1
Would it have a megaphone effect though if not treated or coated....
Old 07-11-2012, 11:32 PM   #2066
derickveliz2
Hilser Funnel in process... kind of!
pictures of the cut out section soon...
Hilser Funnel
D.
CLA 250, 4MATIC
Old 07-12-2012, 01:41 AM   #2067
derickveliz2
Area to but removed...
I'm sorry for the quality of the pictures, I used my cellphone
D.
CLA 250, 4MATIC
Old 07-12-2012, 01:43 AM   #2068
derickveliz2
Just for FUN...
Painted calipers the other day!
D.
CLA 250, 4MATIC
Old 07-12-2012, 03:13 AM   #2069
sqcomp
Roadrunner Jr.
sqcomp's Avatar
@ sick...
I'm not so sure that we'll have much of an effect that far off axis.
@ Derick...
Go to Toyotapartszone and get another pair of a-pillars. It's a just in case thing. I'm off to do my Army drill thing for the next two weeks and that pillar thing is one of the first things I need to do when I get back...seeing where my tweeters are now.
― Thomas Paine
Old 07-13-2012, 11:39 PM   #2070
derickveliz2
@ Derick...
I saw a picture showing your tweeters in the sail panels! I was going to go that way too.
But now I can't wait for some extra time and cut the right side and move right tweeter there, the stage is impressive to me, and sweets my taste for Front Stage better than before.
Good luck in the next 2 weeks! Will be hovering around here!
D.
CLA 250, 4MATIC
