![]() ![]() ![]() Drives: 2007 Liftback Join Date: Mar 2012
The bolt that holds on the tensioner....
![]() OK, what size is that bolt that goes to the top of the rail that the alternator top bolt bolts to (if that makes any sense, LOL) Somehow, I lost mine. (I know it seems like I start a new DIY thread everyday) |
![]() ![]() Drives: NCP91 Join Date: Jul 2012
12 mm hex M10 x 1.25 mm
from memory; I will need to be at work on Monday to confirm this. |
Maybe I should clarify....
![]() Not sure how I lost mine. :/ |
That one is not a bolt, but rather a threaded stud into the top of the block that the arm slides onto. Then a 10mm x 1.25 nut holds the arm in place.
| Belt Tensioner for the Yaris | fmicle | DIY / Maintenance / Service | 25 | 11-26-2022 11:37 PM |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Warning - Broken control arm bolt! | CB900F2 | DIY / Maintenance / Service | 460 | 08-23-2020 05:54 PM |
| Over tightened bolt | KSIbucky | DIY / Maintenance / Service | 5 | 09-02-2011 06:31 AM |
| bottom long bolt for alternator | yaris9876 | DIY / Maintenance / Service | 5 | 05-24-2010 02:02 PM |
