Old 08-27-2011, 06:00 PM   #181
CueBall
Ruler of the free world
Drives: 09 Yaris 2D HB
test tach signal?
I installed my tach today. The light works, but the tach doesn't.
I know I have power and ground because I can test those with my test-lite.
Is there any way to test the tach signal circut?
I am useing the tan wire furthest to the left on the OBD connector, as shown in this thread.
I get no lite with a test light on that wire, but my volt meter reads about 6.8v.
CueBall is offline   Reply With Quote
Old 08-27-2011, 09:11 PM   #182
Never use a test light on a "signal". Test lights draw current and connecting one to an ECM signal could potentially damage the ECM.
That being said, it is hard without an oscilloscope to verify a pulsed signal.
Old 08-28-2011, 09:33 AM   #183
Lil Abner
Drives: 2009 3dr LB Manual
Well, the tach signal needs a solid ground in order to work. That being said, are you sure you don't have your positive and negative wires flipped? Also, HOW did you tap into the tach signal wire? Did you use a BLUE t-tap or scotch lock?
Old 08-28-2011, 04:37 PM   #184
CueBall
faulty tach
I hope I didn't hurt the ECM. It seems to be running ok so far.
Turns out I had a bad tach. Wireing was fine. Works good now with new tach.
I actually put a pin in the port (for tach signal). I hate to splice into wires if I can avoid it. Thanks for the replies.
Old 09-01-2011, 10:34 PM   #185
isra
isra's Avatar
Drives: 2007 Yaris hb
Is there some other place i can get tach signal from???
iSRA
isra is offline   Reply With Quote
Old 09-01-2011, 10:56 PM   #186
Yes, on the cluster connector or ECM connector. All three locations are tied to the same signal.
Old 09-02-2011, 12:54 AM   #187
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
Why do you want some where else?
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 12-18-2011, 07:04 PM   #188
Strider199
Strider199's Avatar
Drives: Black 2012 Yaris 3door 5speed
Ok I think it's time those with a 2012 yaris without a tach start posting their installs.
I cant believe my 5 speed manual doesn't come with a tach. I'm looking for a good spot to mount a tach which is close to the connections needed. Air bags in the a-pillar make me nervous.
Who's first?
New to the Toyota World, be nice.
Strider199 is offline   Reply With Quote
Old 12-18-2011, 08:04 PM   #189
Who's first?
For the 2012, the Tach signal is still on pin 9 (light green wire for 2012) of the OBD connector.
The pink wire on the key switch is still ignition switched power for the 2012.
Old 12-28-2011, 02:50 PM   #190
Strider199
Strider199's Avatar
Thanks for the info CTScott.
I went out today to a few stores looking for a tach I like. Did not find one. I bought a new horn which I will install when it warms up this weekend but I'm still looking for a decent tach. Auto Zone and Canadian Tire just don't have the selection. On-line they have a ton of gauges but I hate the extra duty I have to pay being in Canada. Any stores around the Hamilton - GTA area which have a decent selection?
Old 02-11-2012, 09:52 AM   #191
avlisk
Drives: 2002 Rio Cinco
What about a Toyota tach from the SE model? I'm considering buying a Yaris LE automatic, but I want a tach, too. So, would an SE replacement tach be an easy installation? And fit right in the dash where there's a big, round space for one? Thanks in advance for your opinions.
Ken S.
avlisk is offline   Reply With Quote
Old 02-11-2012, 10:21 AM   #192
Ken S.
Yes it will work, but finding one will be very difficult until the 2012 has been out long enough for some to make it to junkyards. Per your other thread about buying one from the dealer; You may have a hard time getting the dealer to order a cluster for you, as they often will not let you order a cluster that doesn't match your VIN configuration. If you are buying a 2012, you can try to make your sale dependent on them ordering the cluster (just make sure you get it in writing on the contract).
Old 02-11-2012, 01:09 PM   #193
RedRide
RedRide's Avatar
On the '09, it the light brown wire for the tach signal.
The brown wire is in the exact same position as the blue wire.
It had me stumped for short while when installing my tack as I also have an '09.
Old 07-31-2012, 07:17 PM   #194
ijose 845
ijose 845's Avatar
Drives: 07 Toyota Yaris
hey im having problems with the greenish blue wire for the rpm read outs. do i stick the wire in the same slot as the greenish blue one? or do i splice the green and the greenish wire together?
Angry Bird Crew #1
ijose 845 is offline   Reply With Quote
Old 07-31-2012, 07:40 PM   #195
Always make a good connection with wiring. Either use a tap splice connecter (that crimps onto the two wires cutting through the insulation to make contact with both wires) or solder and heat shrink the connections.
Old 07-31-2012, 09:56 PM   #196
ijose 845
ijose 845's Avatar
oh okay i got it thanks! and as for the light wire is it okay if i put it on the ingition fuse?? it works pretty well for me now! will it hurt anything?
Angry Bird Crew #1
Old 07-31-2012, 10:40 PM   #197
That's fine if you do it with an add-a-fuse or tap the pink ignition wire on the ignition switch connector. Shoving the fuse in with the wire under it is not a good way to do things.
Old 07-31-2012, 10:50 PM   #198
ijose 845
ijose 845's Avatar
ahh thats what i did....but its in their really snugg. im just afriad to cut any of the factory wires cause i dont want to cut too much or mess up and ruin the car completely :/
Angry Bird Crew #1
Liftback Spoiler Installation Toddhata Cosmetic Modifications (Exterior/Interior) 25 08-09-2009 01:26 AM
US Yaris: Adding a tach? Thirty-Nine General Yaris / Vitz Discussion 159 04-05-2007 08:23 AM
