Old 12-14-2009, 10:19 AM   #1
nerisahzn
Drives: Yaris T3
Parking lights and Tail lights not working
Hi guys,great forum. I've just purchased a 2007 hatch for my wife about two weeks ago. Everything was fine until yesterday when she noticed that the tail lights were not working. I've checked every fuse under the hood but still no joy. is there anything else theat could have gone wrong. any help woul be appreciated.
nerisahzn is offline   Reply With Quote
Old 12-14-2009, 01:11 PM   #2
The taillight fuse (labeled "TAIL") is under the bottom of the dash, in the secondary fuse panel.
Old 12-15-2009, 04:43 AM   #3
nerisahzn
Drives: Yaris T3
thanks a lot. finnaly got it working
Old 08-26-2012, 07:26 AM   #4
Marius
Drives: Toyota Yaris T1
Hi, I have the same problem but I find no fuses labeled "TAIL" in my secondary fuse box under the dash. All the fuses seems fine as well. Any alternative ideas?
Marius is offline   Reply With Quote
Old 08-26-2012, 08:41 AM   #5
What year is your T1?
Old 09-17-2012, 02:45 PM   #6
walt101786
Drives: 07 Toyota Yaris Hatch-Back
if all fuse are working fine then it maybe the bulbs are dead, which means u might have to replace the bulbs....
walt101786 is offline   Reply With Quote
Old 08-27-2014, 03:32 AM   #7
toyota
SRacer
toyota's Avatar
Drives: Toyota Yaris 2007
Send a message via Yahoo to toyota
so what happens if only one side of the brake light works and not the other? can that still be the fuse?
"If I go down, I do time. I do real time. I don't know about your other drivers but when I see flashing lights in the mirror I don't stop."
- Dominic, Fast & Furious
Learn The Truth about Six Pack Fast!
toyota is offline   Reply With Quote
Old 08-27-2014, 06:25 AM   #8
No. One fuse drives both, so that is most likely a bad bulb.
Old 11-03-2015, 09:33 PM   #9
Taff
No tail lights
No tail lights working front or rear on my Yaris, no warning sound when light switch left on and door opened, no front or rear fog lights. All other lights working.
All fuses and relays checked out ok by auto electrician but he didn't have time to do a full check of system.
Any ideas anyone?
Taff is offline   Reply With Quote
Old 11-03-2015, 10:03 PM   #10
Any ideas anyone?
Recheck (or replace) the PANEL1 fuse in the under dash fuse panel.
Old 11-04-2015, 04:47 PM   #11
Taff
Tried that and panel 2 fuse but still no lights.
Old 11-04-2015, 05:32 PM   #12
bairjo
Bad switch? Check all grounding points. also, did you add anything like trailer hitch wiring?
Old 11-04-2015, 05:47 PM   #13
Taff
Nothing added. Lights just stopped working. Where would I find the grounding points?
Anyone have the link to a video on cleaning the contacts in the light stalk? Saw it mentioned in a thread but couldn't find a link.
Old 11-04-2015, 08:53 PM   #14
You said that all other lights work - So, the headlights come on, but the tails, fogs do not?
Does the indicator come on in the cluster?
Does your Yaris have daytime running light?
Old 12-04-2016, 10:39 AM   #15
siyanda.dlamini
Drives: Toyota Auris
I am having the same problem guys please help
siyanda.dlamini is offline   Reply With Quote
Old 01-16-2017, 08:36 AM   #16
shozi
Drives: toyota yaris 2007
I have exact the same problem on my toyota yaris 2007- my park lights,dashboard light, member plate aren't working I have checked fues is not blown ,bulbs still ok.Now fuel guege is not working properly(mixedup)
shozi is offline   Reply With Quote
Old 01-16-2017, 09:33 AM   #17
shozi
Mine was previously adding trailer
DIY LED Tail (Rear) Head Lights dg4rez DIY / Maintenance / Service 11 12-21-2009 04:10 AM
Smoked tail lights: film, paint or replace? Herbicidal Cosmetic Modifications (Exterior/Interior) 30 10-19-2009 02:01 PM
Tail lights for 09 sedan piepie Cosmetic Modifications (Exterior/Interior) 7 06-03-2009 09:24 AM
JUST GOT MY JDM TAIL LIGHTS!!!!! falkor_99 Cosmetic Modifications (Exterior/Interior) 12 10-01-2007 11:25 AM
FS: Yaris Liftback Tail Lights Stock OEM tekmoe Items for Sale by private party 5 06-15-2007 11:57 PM
