![]() ![]() ![]() ![]() Drives: 09 3dr LB MT Join Date: Aug 2009
Curb Hopping Does Not Work Too Well In a Yaris...
So my car this morning, at approximately 5:10am, my car decided it wanted to attempt to hop the curb. The result was not so good...
I thought it was just a flat tire on the driver's front, and a bent wheel and flat tire on the passenger front side. Not the case. Both front wheels were bent. Thankfully the tire was still ok, so I had the 3-season tries (Hancook Optimos, bought new this past June) swapped over to the wheels I have for my winter tires. However, my passenger front tire is also tweaked a little. So it looks like I need a new control arm on that side. Placed an order for one, and it's supposed to be overnighted to me and be here tomorrow so I can get it fixed before I need the car this weekend. We'll see what happens. I'll upload pics as soon as I get a chance to edit them. Each file is a little too big to upload at this time.
2009 3dr LB MT Meteorite Metalic. Car bought 8/7/09. Now over 89k miles of trouble free driving, other than user error!!
no show, no go :(
ouch...
double ouch
Form>Function
Dang man you gotta control those wild Yarii, so sorry to hear this happened.
You might want to also order the mounting bolts for the control arm and the tie rod end. Based on what I found with the first Crashy, when the control arm gets bent, so do its mounting bolts and the tie rod end.
![]() ![]() ![]() Drives: 08 2Dr LB Base, Silver Join Date: Jan 2011
My Yaris had a set of Scion XB 7-spoke wheels and tires (185/65/R15) installed, which made the car a little taller.
In that configuration, I once drove forward to exit a parking space (no car in the space in front of me) and ran over one of those concrete parking chocks. Imagine my surprise when I realized nothing happened to my car at all. |
#7 | |
So an update...
The control arm arrived around 10am this morning. We got that swapped out and down for an alignment. Picked it back up this afternoon, drove home. Noticed a shaking at speeds upwards of 40 and above. Also a clicking noise while turning right at speeds above 10mph. Washed, waxed, detailed, checked tire pressure (right front was low, as was left rear). Filled them back up to 35psi, and went for a test drive. At first the shaking seemed better, but definitely came back. Got home, and I had a funny felling and checked the psi again in the right front (fine) and the left rear (back down to 25psi). Cranked up the air compressor again, filled, pulled the nose off, and a loud hissing continued. My left rear rim is bent as well... I will still be traveling to the Hamburg, PA meet tomorrow, but driving with a doughnut on the left rear (thankfully I know enough back roads I can take to avoid the highway as that would not be too safe under the current conditions).
The mounting bolts appeared to be in good shape. The control arm wasn't horribly bent. Looking at it by itself, you couldn't really see that it was bent. But on the car with a tire on it, you could see it. It was maybe at most, 1/2" - 1" off.
Mr. 155 and climbing
how far is the trip? those donuts aren't good for very far. best of luck and be safe.
![]() Drives: 2007 Yaris Sedan Join Date: Nov 2008
Still waiting for the pictures.............and a sign that all is well.....er.
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
oh boy! Yeah, the donut only has a limited amount of miles. good luck!
It's been a long day. I'll get to the pics hopefully tomorrow.
Yes things are better... Thank you 12Yaris for the wheel and tires!
![]() ![]() ![]() Drives: 2008 5 sp. LB Join Date: Oct 2010
While on a cattle ranch dirt trail, and going walking speed, the damn cell phone rang and like a dummy I answered as it was business/$$ related. While continuing to drive the trail (not a road, a temporary trail across a field to a solar job I was doing) and answering the call I neglected to miss the boulder I had dodged on the way in. It lodged under the body, no damage to the running gear, but the mighty Yaris was now high centered and not going anywhere. The cowboy riding shotgun just looked at me as I shut down the engine while completing the phone call (got the job the call was about, so worth it as it was time related crane work and voice mail doesn't hack it).
We got out and eyeballed the situation, and as we were on a 10% grade I put it in nuetral, took the parking brake off, and we both lifted on the right rear corner, him on the fender and me on the bumper. Being REAL careful not to unstick it but then lose it down the slope, we were easily able to raise it enough to kick the rock free and continue our drive out of the field. It was about as hard as getting an ATV unstuck, light is good in a situation like that, if this didn't work, he indicated his horse could pull it free..... |
#15 | |
Finally getting around to resizing then uploading pics...
![]() ![]() ![]() Drives: '08 Yaris LB Join Date: Jan 2012
OUCH!
Any charges laid by the officer on-scene?
| 06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 02:14 PM |
| Persuade me to buy a Yaris! | TONIZZLE | General Yaris / Vitz Discussion | 48 | 09-09-2011 11:31 AM |
