![]() Drives: 03' 1.5 vitz rs Join Date: Feb 2012
Can I change my sway bar & endlink bushings myself? What's the steps & difficulty leevel
Endlinks in theory are not too hard. Two nuts on either side. However, they often seize and for the inexperienced this can be difficult to deal with. Often comes down to cutting them off. The swaybar itself is buried and it's not likely you will want to do it yourself. Pretty sure the subframe has to come out to do it, but haven't looked too close.
If you have a cut-off tool I wouldn't hesitate to try the endlinks. Worst case scenario you have the cut the endlink bolts off. Cheers. |
End links are easy, and we sell adjustable high grade ones for the Yaris.
The sub-frame has to be partially dropped to snake a front sway bar in there -- the rear sway bar is very easy.
| Tags |
| end link, sway bar |
| DIY - rear sway bar [pics] | cali yaris | DIY / Maintenance / Service | 199 | 07-28-2022 05:25 AM |
| My Ultra Racing rear sway bar install | CtrlAltDefeat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 49 | 03-03-2011 02:08 AM |
| Which rear sway bar? | IsLNdbOi | Performance Modifications | 46 | 11-05-2009 06:07 AM |
| Which front bar do you prefer? Strut or Sway? | TitaniumBarbell | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 10-16-2009 11:52 AM |
| Rear Sway Bar Instructions - Additional Pics | SeaYa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 02-26-2009 01:05 PM |
