Old 09-17-2012, 02:57 AM   #1
Fidelio
EcoFriendly
Fidelio's Avatar
Drives: 2007 Vitz HB
A/C Compressor
I looked in the manual and I didnt find anything that is related to an AC clutch + pulley assembly.
Does anyone know if the AC compressor has a clutch assembly that can be changed?
I also tried looking for toyota OEM parts and I didnt see anything. I am wondering if the bearing and clutch assembly of the AC compressor is one unit that is not maintainable by DIY parts.
Fidelio is offline   Reply With Quote
Old 09-17-2012, 10:14 AM   #2
For whatever reason they are not purchasable as separate parts. IT appears that you could definitely remove the clutch/pulley, but then you can't purchase a replacement.
a/c compressor relay unit?? marcus DIY / Maintenance / Service 31 08-27-2013 02:25 PM
A/C compressor yaryar83 General Yaris / Vitz Discussion 3 06-03-2012 10:47 PM
A/C COMPRESSOR BEARING blacks DIY / Maintenance / Service 1 10-27-2011 09:45 AM
A/C compressor - Always on barryware DIY / Maintenance / Service 7 02-20-2011 12:10 AM
What determines the duty cycle of the A/C compressor? LtNoogie General Yaris / Vitz Discussion 43 08-07-2010 12:46 PM
