![]() Drives: future prius Join Date: Aug 2012
Buying a yaris with 106k miles. need some insight
So we found a yaris with 106k miles, its a little more than what i wanted on a car, but we worked out a good price. were are buying it used from a toyota dealership, and they have claimed that they changed the alternator, fixed idle issues, replaced all 4 tires, replaced the front brakes, and some other small details. Also clean carfax, and seems the car received its routine maintenance.
i guess i am just looking for reassurance and asking for your guys personal opinion. Is purchasing a yaris with 106k miles a good investment? the car will be taken on a 1200 mile trip as well from IL to FL in a couple weeks because we are moving |
there is one guy here who has a yaris with 450,000 miles on it. I will say he has probably done quite a bit of maintenance to it (I don't know for a fact) but it is out there that these cars will last. (can't think of his user name)
my goal is to get as much out of it as I can. really anymore, 100k miles is nothing on a car and especially a toyota or honda. if you do feel you need a second opinion, most mechanics will give it a once over for a small fee just to tell you everything is either good or not. I usually get someone to look at a car that I am thinking about purchasing unless it has very few miles on it. I bought my yaris used and it had 18,000 miles on it and was still under warranty. I think some of the veteran yaris owners may chime in on this one as these things do last quite a while and I don't know of any mass problem with these cars. generally, they are good little cars. |
I would be asking question about the "idle issues". Was the CEL on? What did they do to "fix" the issues. You dont want that CEL coming on again!
Are they warrantying the car and if so for how long? Is the CEL covered? How much are they getting for this car? If its more than $8000 its too much for my blood. But overall the car should be reliable enough.
Milage wise, 106K with these things is nothing really. What is your end goal? Buy it and hope for 10 more years, or 5?
What year is it? Since the alternator has been replaced, I'm guessing it is an '07 since they had issues with the voltage regulator. Sedan or Hatch? And, what is a 'good deal'?
![]() ![]() ![]() Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
I have an '07 sedan with just under 110,000 miles. I replaced the water pump around 40,000 miles, and that's pretty much it. Still runs great, and I'm planning on keeping it for quite a while longer. I don't think you should be that worried about the miles.
One thing I did over the summer helps illustrate, IMO, that you are right. I checked (online) the Blue Book value of my Yaris. Just for kicks I upped the mileage to 300k to see how much the value would go down. It didn't go down at all -- not even one dollar.
Remove the oil cap and look into the oil fill hole to see if any varnish / baked on oil . Will need a flashlight to get a good look . Have them give it a spark plug change . Plan to get the sedan plugs done at 90,000 miles or so . Due at 110,000 miles if I remember correctly . Also look for oil leaking from valve cover or other areas . Would also take it to a MIDAS / MONROE or other shop to have it put on a lift to look under car for oil leaks ,etc... $4,500 would be fair price . Best of luck .
#8 | |
#9 | |
#10 | |
#11 | |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
I previously had an Echo (same platform) that had 318,000 when it was crashed. I took it on a cross-country trip with over 300,000 miles on it. It did fine.
I'm hoping the current Yaris treats me the same. 106,000 miles is barely broken in. |
The Flying Tomato
Drives: 2009 Red Yaris Hatchback Join Date: Dec 2009
There is a whole forum post on what maintenance YarisWorld members had to do at certain mileage intervals. For the most part, it is pretty impressive:
http://www.yarisworld.com/forums/showthread.php?t=11162 |
![]() ![]() ![]() Drives: 2009, auto, 4dr LB Join Date: Nov 2010
Alternator has been addressed, other issues, waterpump, and control arm bolts make the rounds here.
106k miles really is not a lot of miles anymore. Check brake pads and rotors for wear and any uneven wear. E-brake etc. Belts, etc. Again if you know a mech, take it to he/she and have them look it over. The usual advice. Whenener I've taken a used car out for a test drive, I like to hard brake at speed on a back road somewhere, both in drive and reverse. See how it handles etc. Also fun if a sales guy is aboard. This is a pretty reliable little car Give the tires a kick, cause, well you know. Best of luck! Last edited by NEexpat; 03-12-2013 at 06:55 PM. |
#16 | |
| Which dealership is best for buying new Yaris? | webspa | New YARIS Purchase Forum | 0 | 08-22-2011 01:26 PM |
| One week review after buying new Yaris | Blowtorch | General Yaris / Vitz Discussion | 17 | 05-02-2009 10:48 PM |
