Old 03-24-2007, 10:01 PM   #1
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Rear brake proportioning valve???
My rear brakes are weak, and it's not because they're drum brakes. This winter while on snow packed roads I noticed that no matter how hard I push the brake pedal, the rear WILL NOT lock up (no ABS either ). I could stop faster by pushing the brake pedal and pulling the e-brake simultaneously so that all 4 wheels would lock. Can this be adjusted by the proportioning valve, or could I crank the brake shoe adjusters a few notches? My e-brake has to be pulled to far it seems before it grabs. Maybe the shoes are just out of adjustment. What do you think?
PS. Don't give me any "drum bakes are weak" answers. I understand discs are better but drums are plenty strong enough to lock the stock Potenza RE92's at 10 MPH on snow packed roads.
PetersRedYaris is offline   Reply With Quote
Old 03-24-2007, 10:05 PM   #2
Moose
Resident Redneck
Moose's Avatar
Drives: 07 Polar White Yaris Sedan 5M
It's probably because of the snow- wet weather adversely affects the performance of drums.
My other rides:
2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon!
1999 Honda Civic EX Coupe 5M w/ B18 powaa
1985 Toyota Celica GTS Coupe 5M- track whip
http://www.importlounge.com
Moose is offline   Reply With Quote
Old 03-24-2007, 10:10 PM   #3
PetersRedYaris
No, thats not it.
Old 03-24-2007, 10:19 PM   #4
ChinoCharles
Drives: LB
You checked the cable, right?
Old 03-25-2007, 12:03 AM   #5
PetersRedYaris
Could you be more specific? Do you mean the nut to adjust the cable tension right on the bottom of the e-brake handle?
Old 03-25-2007, 02:05 AM   #6
Black Yaris
der Zeck
Black Yaris's Avatar
Go to the dealer, tell them, I am not sure if we have self adjusting rear brakes or not, if they are self adjusting you are SOL
Old 03-25-2007, 02:18 AM   #7
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Toyota did that for safety so people don't go spinning down the road like tops in their Yarii. That's how they can get away without putting ABS on the car.
This is probably also why the brakes are very soft and light until you really push the pedal.
Old 03-25-2007, 04:32 AM   #8
Pavel Olavich
Drives: 2007 Yaris LB
Sorry but that reason sounds lame....I would suggest the OP take his car to the dealer and stop reading guesses from this site...I can get my 2007 LB back tires to lock up, no problem.....
Pavel Olavich is offline   Reply With Quote
Old 03-25-2007, 08:49 AM   #9
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
yea i suggest take it to the dealer and get it checked out.....if they say anything about replacing it and u know for a "fact" that it doesnt need replacing or whatever.......they are just taking your money....
Australia has abs as standard :)
Old 03-25-2007, 12:39 PM   #10
joey1320
joey1320's Avatar
Drives: Yaris LB
the drums should lock as the front if you press the pedal all the way like you said. since you said that the ebrake is high when engaged you may have the shoes out of adjustment. take it to the dealer and tell them your problem.
joey1320 is offline   Reply With Quote
Old 03-25-2007, 12:49 PM   #11
PetersRedYaris
All right, all right, I'll take it ot the dealer. It's such an inconvienence though.
Old 03-25-2007, 03:26 PM   #12
drell42
Drives: Blank
The thing is that the yaris, al least in Canada, has EBD, wich makes it so that under heavy breaking that the breaking force is pretty close to equal. So your rears are extreamly unlikely to lock-up, even under snowy conditions
drell42 is offline   Reply With Quote
Old 03-25-2007, 04:48 PM   #13
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
Question ...before you take it to the dealer
...on other toyota's I've owned ('84 corrolla, '87 pick up, and a '94 corrolla, all had rear drums) you could adjust the rear brakes by 1) drive in reverse (5-10 mph) 2) then quickly stop using the hand brake...
I looked in the owners manual, and couldnt find any info...but its worth a shot.
fu_im_from_texas is offline   Reply With Quote
Old 03-25-2007, 09:49 PM   #14
largeorangefont
Break'em off some.
I would definately take it to the dealer to have them look at it.
I've never driven a car with the braking feel like the Yaris. An Xa with ABS doesn't have the same feel. It feels like a normal car. with a progressive feel. It is very tight and brakes hard with little effort.
In the Yaris you have to push the pedal down pretty far to really get it to stop. It is more like a linear feel, and very soft at the top of the pedal travel. It isnt a bad thing, you just get used to it.
I've have yet to lock a wheel up in my LB. I did put better tires on it in the first week, so that is probably a big part of it. I think the brakes perform pretty well.
PetersRedYaris - Take a picture or count the clicks you have to pull up on your ebrake. That at least will see if the shoes are adjusted correctly.
Old 03-25-2007, 10:01 PM   #15
AaronATL
AaronATL's Avatar
Drives: 2007 yaris hatchback
brakes... brakes... brakes.....
ahhh who needs em anyway when we could use arrestor cables
Yarisworld!!!
AaronATL is offline   Reply With Quote
Old 03-25-2007, 11:23 PM   #16
PetersRedYaris
Seven (7) clicks untill it holds the car. Now many clicks do you all get when you pull up on the e-brake?
Old 03-26-2007, 12:10 AM   #17
joey1320
joey1320's Avatar
Drives: Yaris LB
since you dont want to go to the dealer, have you checked behind the backing plate for any kind of adjusting hole?
DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads ChinoCharles DIY / Maintenance / Service 40 10-13-2017 06:23 PM
rear fog light and tuned rear lights lefti696 Cosmetic Modifications (Exterior/Interior) 0 11-09-2006 04:06 PM
