Old 09-06-2012, 12:59 PM   #163
Originally Posted by SAV912 View Post
With all of the "luxury" (and I use that lightly) items you are adding, I assume that Crashy II will remain enclosed?
Love the work, but it seems prohibitive if you're pickup trucking it like Crashy I. Not that I don't approve of that.
-C
I'm just lazy. I don't like cranking windows or turning keys in locks. No matter what I do with her, the front doors will remain intact, so the power kits will be handy. The hatch is still TBD, but for now I like being lazy.
Old 09-07-2012, 12:36 AM   #164
henrylee
henrylee's Avatar
Drives: 2011 Yaris Sedan Red Power pkg
Crashy II is so so cool...
SOLD: 2011 Yaris Sedan ll Barcelona Red ll Auto ll Power Pkg ll Scion 7 spoke Wheels ll Llumar tint ll "S" Body Kit
http://www.yarisworld.com/forums/showthread.php?t=38682
henrylee is offline   Reply With Quote
Old 09-11-2012, 11:07 PM   #165
Old 09-22-2012, 06:38 PM   #166
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
This thread is fantastic...
On Instagram
On Wheelwell
Old 09-22-2012, 09:15 PM   #167
Astroman
Modded Moderator
Astroman's Avatar
agreed.
Old 09-22-2012, 09:43 PM   #168
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
why would you want to put all of this on a rally car?
Old 09-22-2012, 09:45 PM   #169
She will not actually be a rally race car, but that's kind of the overall look I am headed for.
Old 09-22-2012, 09:48 PM   #170
Old 09-22-2012, 09:49 PM   #171
Golddeenoh
Golddeenoh's Avatar
street usable rally car? also known as a wifey mobile that she can, if necessary, take in an emergency off road trip. Or for you the occasional off road trip to enjoy the car.
Old 09-22-2012, 09:52 PM   #172
Golddeenoh
Golddeenoh's Avatar
I have that problem from time to time with my new hella horns. sometimes i am really loud and other times silence. my wife laughs at me when it doesn't work then a few seconds later i can hit the horn and it works.
Old 09-22-2012, 10:01 PM   #173
Mine wasn't intermittent. In my case the wire had a resistance of almost 3K ohms, which was enough to prevent the horn relay coil from energizing.
With yours being intermittent, it may actually be a damaged wire in the spiral cable. Try holding the horn on, while rotating the wheel from side to side. If it cuts in and out, then the spiral cable is the culprit.
Old 10-04-2012, 02:55 PM   #174
ern-diz
ern-diz's Avatar
I had a strange issue with her today. I had a need to lean on my horn (due to an idiot who ran a red light and almost clipped me). When I leaned on it it was silent, so I had to revert to a flagrant bit of international hand gestures.
Tonight I did some troubleshooting, but was assuming that the issue was a broken wire in the spiral cable. The actual problem turned out to be that the wire between the horn switch and the spiral cable was damaged when the airbag deployed. It wasn't visibly damaged, so I didn't notice it when I replaced the airbag.
So, since I am the person who's name is synonymous with Yaris cruise control, I figured the simplest fix would be to install cruise control on her. (Since the OEM cruise control stalks that I sell have the wiring harness attached with the integrated horn wire).
I absolutely love when u use something not working as an excuse to upgrade an entire system i.e. horn not working so I'm getting cruise control...not the first time I've seen u do that between crashy 1 & 2 and I just had to let u know how awesome it is lol.
On Instagram
On Wheelwell
Old 10-04-2012, 03:04 PM   #175
Much to my wife's chagrin, I use that same theory with everything that I work on.
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
What Car Mechanics Don't Want You to Know!! daddz07 DIY / Maintenance / Service 16 04-17-2011 10:10 PM
