Old 10-07-2012, 09:29 AM   #1
thefalls
Drives: Axio GT
Head gasket
Hi,looking for metal head gasket?
Heard about cometic,anyone has any idea who sells them?
Whats the stock head gasket thickness?
And what is the thickness of the cometic head gasket?
Many thanks.
thefalls is offline   Reply With Quote
Old 10-07-2012, 01:14 PM   #2
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
man i dont know if they even make one for the 1NZFE motor. Ive always used stock head gasket on my street car builds. give them a call or email them. here is a link http://www.cometic.com/contact.aspx
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 10-07-2012, 02:52 PM   #3
thefalls
Drives: Axio GT
Thanks for the reply.Will definitely contact them.
Old 10-07-2012, 08:35 PM   #4
I don't think Cometic has a yaris/1NZ gasket, but maybe. Toyota isn't listed on their site.
I use a stock gasket with no issues.
Old 10-08-2012, 02:27 AM   #5
thefalls
Drives: Axio GT
In fact a friend is having some issues. Most probably his head is warped,car is drinking coolant.So he will have to re-surface the head and go for thicker head gasket.
Thats why i am looking for thicker metal head gasket.
I suppose we could use two stock metal head gasket,as it is aftermarket metal ones are multi-layered.
Opinions?
Thanks.
Old 10-08-2012, 03:04 PM   #6
I've never done this, but I know people successfully double up gaskets, especially metal ones like the OEM Toyota gasket. Pretty much any shop can make you one as well.
Old 10-08-2012, 03:20 PM   #7
Jason@SportsCar
Opinions?
Thanks.
Why do you want a thicker one? There is space to safely deck the head and use a stock gasket, we have done it on a number of engines.
Old 10-08-2012, 03:24 PM   #8
thefalls
Drives: Axio GT
Thanks Jason and Garm,this is the exact information i was looking. I figured that finally we may have to use two stock head gaskets but i didnt know that i can deck the head and still use the stock head gasket.
We learn something new everyday!
Many thanks!
Old 10-08-2012, 03:29 PM   #9
Jason@SportsCar
Many thanks!
I don't know what the limit is (I cant give you the specific number) but we had our engine guy deck it just for the purpose of a compression increase, so we took a good bit off. Just cleaning up after an overheat should be a minimal repair.
If his is to far gone I have a spare head, less than 1500 miles all stock and complete, (just wanted a spare when we were doing R&D with the early cams, but never used it).
Old 10-09-2012, 11:15 AM   #10
thefalls
Drives: Axio GT
Many thanks for the help,but i am mile and miles away from you.And shipping is a real killer.
As one problems dont come in ones,now i just discovered that we have the know issue of leaky head gasket with oil traces by the block/head and timing chain area.
Also around the block/head area all around.
But it doesnt change the oil level,but it needs to be looks at :(
Old 10-11-2012, 01:10 PM   #11
thefalls
Drives: Axio GT
Right i found some Fel pro head gasket.
http://www.partsgeek.com/catalog/200...ad_gasket.html
And head bolts with washers
http://www.familycar.com/store/?Ntt=...+bolt&oes=true
Old 11-10-2012, 11:43 AM   #12
For a head? Not so bad.
Old 11-12-2012, 12:26 AM   #13
jetblast
Drives: Gen 1 XB
I have a former racing source that probably would design something. All depends on how busy he is with bigger stuff.
jetblast is offline   Reply With Quote
HEAD GASKET ; How long to replace it ( hours ) ? Hershey General Yaris / Vitz Discussion 49 05-22-2017 12:40 PM
Custron T1062TYT Review (Long) mr.steevo In Car Entertainment + Electronics (audio / video / alarm) 1 11-24-2011 02:13 PM
Head Gasket Leak Hershey DIY / Maintenance / Service 45 11-11-2010 10:19 PM
Another 2010 head gasket oil leak found ... Hershey General Yaris / Vitz Discussion 4 10-20-2010 12:18 AM
GO FOR IT ? Trade 2010 3 door ( W/oil leaking head gasket ) for 2010 sedan Hershey New YARIS Purchase Forum 9 10-10-2010 01:06 AM
