Old 10-20-2012, 01:35 AM   #1
cougar65
cougar65's Avatar
Drives: 2010 yaris 5door
Muffler rattle noise
So, I have had my axle back in for some time now and ever since I've installed it at certain rpms it woud make a rattleing noise. It is NOT my heat shield. Sound almost sounds like rocks in my muffler, Im certain its not my catalitic converter sence i have no CEL.
Could it be the gasket? I reused it instead of buying a new one. Gas escaping and making that aweful noise? I have shaken the muffler to try to hear if anying is oose inside and i dont hear anything. It like to make the noise when its waremed up and ussually under a load.
cougar65 is offline   Reply With Quote
Old 10-20-2012, 08:45 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
did you assemble the spring bolts properly when you clamped it back together?
Old 10-20-2012, 11:54 AM   #3
cougar65
cougar65's Avatar
so, if i didnt it could make the noise?, ill take it appart and put it back togeter then.
Old 10-20-2012, 11:40 PM   #4
Bluevitz-rs
yeah if the bolts aren't bottomed out or the spring shifted while you tightening it up. Or it could just be a bad weld that broke loose and makes noise at it's resonance frequency of whatever RPM you hear it.
Old 10-21-2012, 11:56 AM   #5
MUSKOKA800
MUSKOKA800's Avatar
Or it could have a loose baffle inside the can itself (corroded or broken weld).
My TRD axleback may have that same issue. 80,000 kilometers of service through four years. I guess it won't last forever.
Old 10-24-2012, 12:30 PM   #6
cougar65
cougar65's Avatar
***Fixed**** Was the jasma stamp that was rattleing... took it off and now its rattle free.
Rattle - Noise when Yaris put in Reverse Jungle Rot DIY / Maintenance / Service 14 08-27-2015 06:32 AM
Rattle noise under the speaker’s cover - sedan karat747 DIY / Maintenance / Service 1 10-22-2011 08:41 AM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 12:27 PM
Rattle noise under the speaker’s cover - sedan karat747 In Car Entertainment + Electronics (audio / video / alarm) 5 09-08-2009 09:30 AM
Rattle noise in the trunk - Pls help! karat747 DIY / Maintenance / Service 10 09-07-2009 08:31 PM
