Old 10-22-2012, 02:07 AM   #19
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Okay, drive in D for a tank and report back. I suspect it'll only improve a bit. And drive like normal no adding miles. We want this to be somewhat scientific ie testing only one variable at a time--- the D vs 3rd gear driving.
To comment on my " I suspect it'll only improve a bit". ---- This is because if your car is still "warming up"....it won't shift higer than 3rd gear. *I need someone to back me up on this because I have a manual and am relying on memory from previous member's threads/posts.
Old 10-22-2012, 02:25 AM   #20
Kar98
Drives: 2011 Scion tC
Originally Posted by P205 View Post
allright i have been driveing in 3 this hole time
And driving no further than three miles? AND letting it warm up for three minutes before driving? Yeah, that will do it. Mystery solved.
Old 10-22-2012, 02:57 AM   #21
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
not to be rude, but:
b20vteg is offline   Reply With Quote
Old 10-22-2012, 03:20 AM   #22
henrylee
henrylee's Avatar
Drives: 2011 Yaris Sedan Red Power pkg
Lol not to be mean but fail...
SOLD: 2011 Yaris Sedan ll Barcelona Red ll Auto ll Power Pkg ll Scion 7 spoke Wheels ll Llumar tint ll "S" Body Kit
http://www.yarisworld.com/forums/showthread.php?t=38682
henrylee is offline   Reply With Quote
Old 10-22-2012, 09:35 AM   #23
charles nelson
Drives: red Liftback
I have a Scangauge II. I let my brother-in-law borrow my Yaris for a week. He complained that he was only getting about 25 mph. When he returned, I had him take me around the block. He put the automatic right into D-3. I pointed out to him that was setting the trans into third not higher gear. He was ticked off that the shift mech was so poorly labeled.
charles nelson is offline   Reply With Quote
Old 10-22-2012, 09:40 AM   #24
NEexpat
Drives: 2009, auto, 4dr LB
I was guessing you were not in third.
Not uncommon, I am currently helping my niece practice for her driving test next month and she often "slams" it into 3rd like Frank Bullit before we get going.
Short trips, cold weather, + the cold engine shifting restriction. Well you were always in 3rd and never going to get out of it.
Hopefully that's it. Keep us posted on your mileage.
cheers.
*Usually takes me about a mile or two, before my automatic is allowed to up shift in the winter, shorter in the summer.
NEexpat is offline   Reply With Quote
Old 10-22-2012, 11:43 AM   #25
P205
Drives: 2008 yaris 1.4
Who has a scanguage? is it just plug and play? where can i get one
P205 is offline   Reply With Quote
Old 10-22-2012, 11:57 AM   #26
P205
Great thanks for the reply, I will now being driving in D " not drrrrrrrrr"
I drive a manual truck all my life, then i have to learn to drive automatic lol
Ill post results soon
Old 10-22-2012, 12:07 PM   #27
NEexpat
You can buy a Scangauge II online.
It plugs into the OBD port.
I personally use an UltraGauge. I prefer it aesthetically, but mostly because I'm a cheap bas.....well anyway.
Old 10-25-2012, 12:38 PM   #28
P205
Update. so I have been driveing in D now. its looking like no change, when my first bar from my gadge gose away i have gone 45 to 47 miles witch is what i have been getting when i was driveing in 3
any ideas?
Old 10-25-2012, 12:57 PM   #29
rningonfumes
Read my posts again about the cold.
Old 10-25-2012, 03:09 PM   #30
P205
yea. humm . i was getting the same mpg in the summer. my cold temp gose out before i leave my street
Old 10-25-2012, 03:41 PM   #31
NEexpat
Forget the bars. I've had my first bar drop as low as 61 and as high as 92. Go by the pump and the miles.
Suggest if you have the time, money and inclination. Fill your tank, set ODO A to 0.0 and go for a long sustained drive at speed, 65 etc. And by sustained I mean several hours, at least 3. Then go top of the tank and see how it went. If you have cruise control lock it in. See if you get in the mid to upper 30's.
I can't believe you're not going to see improvement by just getting out of third. I think the short distances and the temp affect more than anything. I wouldn't be surprised if you got into the low to mid 30's from your city driving.
cheers.
Old 10-25-2012, 04:23 PM   #32
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I have a 2008 yaris sedan Automatic 100% city driving
afe intake
new spark plugs
tightly inflated tires
I drive like a little old lady
usually im the only passenger 155 pounds
I cleaned my maf sensor,made sure it was sealed well
no AC
i don't let it idle for no reason
I feel like im doing everything i can possible do right but still
all summer iv been getting 21 mpg, winters here and im lettting it warm up for about 2 mins still 21mpg
I think your mpg calculations are off as if there was a problem that gave you that much of a MPG decrease from normal a check engine light would surely be on.
My 08 sedan is mostly driven around town and i get around 500kms/300miles per tank which i think is in the normal range.
PS isnt it an 11.1 gal tank?
Have Yaris will travel..
Old 10-25-2012, 05:20 PM   #33
P205
humm who drives in cold weather here
Old 10-25-2012, 06:01 PM   #34
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
You're right Jambo – 11.1gal tank. That translates to 19mpg – SUV territory. lol.
Other options:
1) Commute is two miles - sell your car, ride a bike.
2) Remove your interior, leave the driver's seat.
3) Replace air in tires with helium. It really works!
4) Get rid of the decomposing corpses in your trunk.
5) Lose the girl, save two miles.
6) Lose weight.
All jokes aside, at least you're driving in "D" now.
Old 10-25-2012, 08:00 PM   #35
P205
lol well if i was any lighter float to work. but anyways i guess im just screwd
Old 10-25-2012, 08:19 PM   #36
NEexpat
Seriously, go for a long drive and see what your mileage is.
This will give you some indication if it just your particular commute circumstances or if there is truly something wrong with your car.
And if you mean screwed by owning one of the most reliable and dependable cars on the road today, then we are all screwed.
gas, mpg
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 09:38 PM
Why sub-compacts and compacts get almost the same MPG Kal-El Off-topic / Other Cars / Everything else Discussions 0 08-11-2011 12:51 AM
3000 mi Summer Trip Log...MPG included! slothman86 Fuel Economy Forum 14 07-20-2010 01:15 PM
Better MPG in the City vs. Hwy Loren Fuel Economy Forum 21 01-29-2010 12:49 PM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 07:31 PM
