Old 04-21-2012, 10:33 PM   #217
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I am a bit dismayed actually at the reliability of the motor. I mean really...why can't it handle 25+ psi of boost on stock internals?
Old 04-22-2012, 04:07 PM   #218
Volcano
Experienced Yaris Owner
Drives: Yaris 2013 1.33 Ltr
30000 km just as of today, no probs except the power lock. (Yaris '12 purchase Dec 1st 2011)
Volcano is offline   Reply With Quote
Old 04-22-2012, 04:33 PM   #219
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
30K miles last weekend.. 0 engine problems, purchased Aug 2010. Autocross at least 10 times a year, and 2 track event. That is all day at a track doing high rpm's.
no issues, not even my water pump going bad.
-Derrick-
Old 10-19-2012, 10:51 AM   #220
mkaresh
Drives: Mazda Protege5
We have updated our reliability stats for the Yaris to include owner experiences through June 30, 2012.
Repair frequencies, in terms of repair trips per 100 cars per year:
2010: 14
2009: 7, small sample size
2008: 22
2007: 33
All are better than average.
We have two additional statistics, "Nada-odds" and "Lemon-odds," to indicate the percentage of cars with no repairs in the past year and those that required 3+ trips to the repair shop.
For the years with enough data:
2008: 82, < 1
2007: 71, 3
We'll have further updates in November and February. With more owners involved, we could provide more precise information and provide all three stats for all model years.
To see how competitors compare, and to sign up to help improve this information:
Toyota Yaris reliability ratings and comparisons
truedelta.com
Vehicle reliability, fuel economy, price comparisons
mkaresh is offline   Reply With Quote
Old 10-19-2012, 12:57 PM   #221
bronsin
bronsin's Avatar
How interesting that of some 22,000 people who have read this post, only some 200 have actually had anything to say about it!
Old 10-19-2012, 01:12 PM   #222
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
I'm guessing that 90% of the people are like me; zero problems with the car so far, but want to know what to expect for what COULD go wrong. I'm at about 100k miles (purchased at 42k) and have done nothing besides fluid changes and performance upgrades.
Old 10-20-2012, 05:53 PM   #223
Kal-El
Kal-El's Avatar
129,000 miles. Not a single problem. Still functions as if it was new. Never seen anything like it and I worked at a dealership where I drove thousands of used cars. None had held up like the "cheap" Yaris.
My original brake pads are still 50%.
I'm on the original spark plugs - plan on changing them soon.
Old 10-20-2012, 06:34 PM   #224
suckerface
#1 Lemming
suckerface's Avatar
+1 on the brakes and plugs. I swapped the plugs, just because, at 90k and am doing the brakes before winter fully hits, mostly as an excuse to upgrade some of the parts, not totally because they need it. AFAIK, the plugs and brakes are still from the factory.
Old 10-20-2012, 09:15 PM   #225
nookandcrannycar
Some of that might be because some people have already put the information on another thread...all of my info (except mileage and dates of most oil changes, and my recent tire and battery replacement) are on another thread started by Kal-El. I'm closing in on 231k and the only items other than 'routine' (oil(not as often as many of you)/filter/tires/battery/serp belt/clean rear brake drums/spark plugs/mirror cover stolen/each headlight bulb once and a couple of rear plate lights) have been the front wheel bearings at 110k and the alternator at 159k. I've averaged a bit over 75k for each set of 4 tires. Still original clutch, transmission, water pump, radiator, brakes (about 80% remaining/20% worn at 207k-208k), A/C condenser, engine (except the oil that goes in it,oil filters, and spark plugs at 207-208k), exhaust,etc. With my new tires, battery, and seat covers I found.....It almost feels like new. I agree with Kal-El. Mine has just been an amazingly reliable car....that also gets great gas mileage.
I would be reluctant to give up all the glove boxes, the reclining rear seat back, the keyed hatch release, two front wipers, and the hand crank windows.
Old 10-23-2012, 12:04 AM   #226
Idahotom
Drives: 2008 5 sp. LB
This thread is pretty boring......my '08 is just like every other Toyota I've owned ('90 pickup bought new, worked hard for 245 K, zero problems. '89 All Trac 150K pd, 600 bucks and after 4 years of no problems sold it for 1K. More recently a '99 Rav 4 AWD with 150K that drives like new) and the Yaris shows every sign of continuing this trend. Simple, cheap to operate, and extremely reliable.
Idahotom is offline   Reply With Quote
Old 10-24-2012, 03:31 AM   #227
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
On my 3rd water pump. 120,000km. Does not like high rpm because it's the only time it leaks. If I drive hard once in a while I'll find a pink coolant line on the underside of the hood above the belt. When I drive normal is doesn't leak.
Only other thing was the weak factory clutch started slipping at 30,000km and was replaced with a Celica clutch under warranty. Water pumps were covered too.
Old 10-24-2012, 01:23 PM   #228
mkaresh
Interesting observation on the water pump. Odd that the clutch went so early, good to hear they covered it--this isn't common with a clutch. Something other than the lining?
truedelta.com
Old 10-24-2012, 02:53 PM   #229
nookandcrannycar
Yeah, even before my clutch became 'high mileage' I'd heard (even though it can be hard to get used to) that the clutch in the Yaris would last a long time unless abused. Yarisworld member trini_per4mance got 448,000 miles out of his original clutch. Someone who works for Toyota told me (I don't know if this is true) that a contributing factor for long clutch life in the Yaris (and he was talking about the U.S.) is that it is the same clutch that is in the Scion tC and in the 4 cylinder Toyota Camry (for 2007 at least). If that is true, I wonder if Bluevitz-rs has the same stock clutch I do (possibly a less durable one?) as he has a 2005 and the Scion tC wasn't sold in Canada until 2010 (don't know about the Camry re Canada).
Old 10-24-2012, 04:38 PM   #230
Bluevitz-rs
No the Echo clutches from '04-'05 were all soft. There were some problems with the pressure plate not clamping with enough pressure. I saw it when they took it out and it sill looked like brand new. Both the flywheel and the pressure plate still had the machining marks in them and was still shiny silver.
The Celica clutch is pretty much identical to the Echo except for a stiffer pressure plate.
And it is possible the Yaris clutch is the same as the TC because it's different than the Echo's. I've seen a side by side comparison.
Old 10-24-2012, 04:54 PM   #231
joe keeney
Drives: yaris 2 door hatch
around 37,000 run like new no trouble
joe keeney is offline   Reply With Quote
Old 10-24-2012, 05:02 PM   #232
nookandcrannycar
Wow. Interesting.
Old 11-06-2012, 06:22 AM   #233
bigdoglover
Drives: 2007 red lb
just had to replace the battery at just under 58,000 miles.
bigdoglover is offline   Reply With Quote
Old 11-09-2012, 12:46 PM   #234
bfe71730
Drives: 2011 Yaris 2dr Hachback
53000 on my wifes 09, it's been to the dealer once right after we bought it for bubbles in the window tint, no mechanical problems at all. always use full synthetic oil and k&n air filter. best mpg was 43, average high 30's.
bfe71730 is offline   Reply With Quote
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
