![]() Drives: 2010 Yaris 3 door hatchback Join Date: Aug 2011
Mobil 1 vs. regular oil switch at 30,000 miles
Anyone out there know if it's ok to switch over from factory Toyota oil to Mobil 1 with 30K on the odometer? With all my previous vehicles I'd always switched over at 5000 miles or just after break in oil is due for 1st oil change. I have heard or been advised against higher mileage conversion to synthetics because of potential engine seal problems of which I currently do not have any problems with.
Thanks! |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
30,000 is not high mileage. 30,000 is very low. Go ahead and switch.
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
high millage is above 120k miles and anymore with the current standards that keeps raising.
I switched my oil to Royal Purple at 35k, no problems. Seal issues come from high mileage due to ware and the general drying out of rubber based seals, so no issues should arise unless the seal is all ready faulty or leaking.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
SAve money and run regular motor oil with the recommended change intervals. Your car wont last any longer with synthetic oil. You wont get better mileage (try it and see I did). The engine will last 150,000 miles or more and in fifteen years the rest of the car will be shot and uneconomical/inconvient to fix every three months.
no show, no go :(
he's doing it for the power. yes, mobile 1 makes power. all .25hp...
![]() Drives: 09 3dr HB 5sp Join Date: Apr 2011
Your wallet will definately be lighter, so theoretically you will go a little faster with the switch.
no show, no go :(
haha.
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
I switched to Mobile 1 at 30,000 miles because I ran out of free oil changes at the dealership. Been running to 101,000 fine. Not that much money if DIY anyway. $35 vs. $20. Big deal.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 08:43 PM |
| SHELL : regular motor oil : $1.99 a qt. @ RITE-AID . | gid | DIY / Maintenance / Service | 10 | 01-23-2009 12:02 AM |
| Compiled 1NZFE Used Oil Analysis | craigq | DIY / Maintenance / Service | 7 | 09-10-2007 04:27 PM |
