Old 11-21-2012, 08:10 PM   #199
screenprintr
screenprintr's Avatar
Drives: 2010 Toyota Yaris
I'm really glad my Yaris gets 34 mpg semi around town and highway. However, I had stopping for gas every 3 or 4 days.
Why didn't they think about a slightly bigger tank? What's up with that?
screenprintr is offline   Reply With Quote
Old 11-21-2012, 08:29 PM   #200
matti
Drives: 2017 Yaris L (5sp manual)
I also thought a bigger tank would be nice. Certainly not a deal breaker, though.
matti is offline   Reply With Quote
Old 11-23-2012, 12:10 AM   #201
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
anyone notice lower mpg now that it's colder? why is that? :S
b20vteg is offline   Reply With Quote
Old 11-23-2012, 12:13 PM   #202
cmdjd
Drives: 2012 5 door
Richer fuel/air ratio until fully warmed.
cmdjd is offline   Reply With Quote
Old 11-23-2012, 12:15 PM   #203
cmdjd
Drives: 2012 5 door
Bigger tank, more gallons, more weight, lower fuel economy when full.
Old 11-23-2012, 07:14 PM   #204
2o6
Drives: 2007 Liftback
Depending on where you live, most gas stations have switched to a winter blend of gas, which burns quicker.
2o6 is offline   Reply With Quote
Old 03-07-2013, 04:47 PM   #205
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
There are a lot of factors relating to poor economy in cold weather. Much of it is increased friction from lubricants, plus winter blend gas, and often colder operating engine temps. A hotter engine is usually more fuel efficient (not if the ECU is backing off timing to prevent knock).
Amdkt7 is offline   Reply With Quote
Old 03-07-2013, 08:23 PM   #206
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I get exactly the same effect on my Yaris as with my motorcycle. The bike averages 66 in Winter and 70+ in the Summer.
I got my Yaris at the end of April which was mild Spring into hot summer weather and it's 2,000 mile average was 36.5 mpg.
Then I installed the tooter manifold and the next 1,100 hot Summer weather into milder Fall average was 38.3.
Now the latest 800 mile cold weather Winter average (also with the tooter) is 37.2.
So I can't wait for more than a year to pass so that I can get comparative mileage averages under similar seasonal weather conditions.
Old 04-09-2013, 08:27 PM   #207
screenprintr
What happens when you turn on the Air conditioning? My car barely moved once I turned on the Air today. Yikes!
Old 04-09-2013, 08:36 PM   #208
Amdkt7
Returning to Toyota
Huber Optic film, all the way around the glass. Did not need air today, I know in the past I would have! I did use air on a trip with a load of people (full car) because of the humidity. It did not hurt my mileage much. 38 mpg, 70 mph much of the trip.
Old 05-24-2013, 05:06 PM   #209
peewee1
PEEWEE1
peewee1's Avatar
Drives: 2009 yaris s sedan
M P G
I got tired of hypermiling, tired of the hard ride,tired of coasting down hills. So I lowered the air in my tires to 30 lbs, nolonger do any coasting. I just driver smarter and slower ( under 58 mph). No jack-rabbits and feather the gas pedal,and my mpg has gone from 36 to 41 mpg. The real answer to good mpg is TAKE IT EASY.
peewee1 is offline   Reply With Quote
Old 06-29-2013, 02:43 PM   #210
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Bump. My Yaris is 6 years old now, so I thought I would do a FE check, pleasantly surprised at 5.1L/100km, city and highway. Even now, that is a nice number, and the fact that I have been getting that for all this time makes this a very efficient vehicle!
Old 06-29-2013, 06:02 PM   #211
Amdkt7
Returning to Toyota
Some short trips, or trips with to many stop signs kills my mileage to the low 40's (mpg). Often get over 50 mpg on my trips to and from work. I sometimes can eek out 60 mpg. I use pulse and glide a lot. I have been experimenting with staying in lower gears while accelerating (up to 4k RPM), my trip average does not seem to suffer. Once I reach my target speed I'm in 5th, or coasting as soon as possible. So, it does not seem to matter much how you pulse, low rpm, or mid rpm, the overall mpg does not seem to be effected. The higher rpms gets you up to speed much faster even though the instant mpg is worse, the overall mpg is about the same. Otherwise, highest gear possible is the way to cruise.
When I bought the car I was only hoping for high 30's. What a great car!
Old 07-02-2013, 12:03 PM   #212
charles nelson
Drives: red Liftback
Air Conditioning and MPG
Most modern cars get better mileage using AC with the windows closed at typical highway speeds. Slower...better mpg with the windows open and the AC off. At higher speeds, the open windows cause increased drag. Usually your car's velocity varies quite a lot at lower speeds...urban stop and go type. And the engine has to rev higher to speed up and run the A/C. So for best mpg, open windows at slower speeds and A/C when cruising down a highway.
At highway speeds and the windows open, I get a very loud low frequency thumping from air pulsing into the vehicle. With the windows closed, there is very little air noise. Noise is wasted energy. Some new cars now have air speed controlled louvers in front of the radiator to deflect and smooth the air flow over the front.
charles nelson is offline   Reply With Quote
Old 07-02-2013, 01:48 PM   #213
Amdkt7
Returning to Toyota
A lot of hyper-millers have found that AC on anytime is worse then having the windows down.
I coast down the same hill every day and have not been able to detect any difference in the coast with the windows up or down (though I usually only roll down one).
It may vary from car to car. Some cars may have a less efficient unit that really hogs the power.
Old 07-26-2013, 07:16 AM   #214
bigdoglover
Drives: 2007 red lb
just filled up yesterday and i manually check my mpg every tank. with the hot weather and using a/c the last week my yaris only got 34 mpg. i normally get 38 mpg without even trying so using the a/c really sucks the mpg in my yaris. i need a more fuel efficient car but this one is paid for. it just was too hot not to use the a/c
bigdoglover is offline   Reply With Quote
Old 07-26-2013, 08:41 AM   #215
Amdkt7
Returning to Toyota
I guess you do a lot of city driving? Only a hybrid is going to do better I think. Are you driving an automatic? With a stickshift you can pulse and glide, even in traffic to some extent. Very short pulses in lower gears, then coast a little, pulse again.. one can maintain pretty much the same speed as the traffic.
However, on trips to go pick up my kids on that side of town I seldom can wring out 40 MPG, even doing all of that. The rest of the time I usually get over 50 mpg on any trip over 10 miles. Short trips always suck.
Old 10-30-2013, 02:37 PM   #216
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
Good post, nice read. I got 38 mpg (new owner/one month-ish) while doing 80-85 down to st pete and 36 mpg / uphill on way back. Coming off a caprice wagon with an LT1 engine, I am lovin the 38 @ 80-85 mph. I am going to put a TRD high flow filter in, for the increased flow potential, HP gain potential and improved performance/response. However, it is a myth that any high flow or even just new air filters provide better fuel mileage in anything that doesn't have a carburetor. FYI. New air filter will protect your engine and if it is fuel injected, will provide better response, not mileage. This is average user, hyper-miler, well, they get good mileage anyway. Good job, 50 plus, cool. I am also against the start stop feature, as every time you use your starter is one less time you can use it again. If doing this, just get a Prius and enjoy the drive instead. Me, I was afraid of the many Prius failures, and know these cars to be good and dependable. (The Yarii). everything else in the read great, make sure to read the tire sidewall before bumping to 50 psi, as the majority of the market on tires is 44 psi max or some less 35 psi, and some at 51 psi, but more rare. Michelin has a mileage tire for us, but up a size or to a 16 inch and get the handler for performance hounds, the Pilot Sport AS3's.
Fuel Level Gauge Stuck ? - 2007 Yaris Sedan kaboom New YARIS Purchase Forum 9 05-15-2007 02:58 AM
Fuel consumption US Yaris vs. Canadian Yaris Driver Performance Modifications 8 10-29-2006 02:27 AM
