Old 12-04-2012, 05:16 PM   #181
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by TOLMACH View Post
^Tooter: I am pretty sure you can do the whole thing without jacking a car - you just need to be a giant octopus
I already did. Having the front of the car up helped make it easier... and I need all the help I can get.
Old 12-04-2012, 06:46 PM   #182
TOLMACH
Drives: soarer
Installation was pretty straightforward. My advice would be to start with spring bolts (two bolts that connect hader to the midpipe) - I unbolted the header first thus had a little problem with spring bolts later. Bolts other than spring bolts were easy to remove. No issues whatsover with removing the o2 sensor as well.
Fitment: the header fits perfectly (had minor issue with big bolt that fastens the lower part of the beader to the engine - kinda support the header/midpipe coupling).
Driving impressions: no torque loss in the low/mid range.. feels like some gain overall. The car easily hits 100kmh in the second gear (6700 rpm)- not sure it was feasible before.
Could not be happier.
Some pics will follow.
Old 12-04-2012, 08:11 PM   #183
TOLMACH
Drives: soarer
some pics
all top crap removed to access the header
http://photo.qip.ru/users/tolmach/96608749/129640535/
all crap moved to the trunk while working on the header
http://photo.qip.ru/users/tolmach/96608749/129640844/
stock header, heat shiled removed
http://photo.qip.ru/users/tolmach/96608749/129640829/
stock header removed, gasket (to be reused)
http://photo.qip.ru/users/tolmach/96608749/129640832/
traditional pic
http://photo.qip.ru/users/tolmach/96608749/129640833/
http://photo.qip.ru/users/tolmach/96608749/129640834/
inside pic
http://photo.qip.ru/users/tolmach/96608749/129640837/
new header in place
http://photo.qip.ru/users/tolmach/96608749/129640843/
Old 12-05-2012, 11:24 AM   #184
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
some pics
Off Topic, But liked your JL sub setup. Pretty cool. Can you PM me a link or do you have more pictures of your install?
JustDidIt is offline   Reply With Quote
Old 12-05-2012, 03:32 PM   #185
TOLMACH
Drives: soarer
^ Thanks.. Sure I can (PM-ed)
Old 12-09-2012, 10:53 PM   #186
DJYojimbo
Drives: 2012 Grey Toyota Yaris SE
I know this header is ceramic so there's no need to wrap it right?
DJYojimbo is offline   Reply With Quote
Old 12-09-2012, 10:56 PM   #187
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
DO NOT WRAP A HEADER!!! wrap is bad avoid it, it holds moisture and increases corrosion. Its coated leave it as is.
Old 12-09-2012, 11:01 PM   #188
DJYojimbo
Thank You for the advice
Old 12-10-2012, 12:17 AM   #189
TOLMACH
Drives: soarer
The producer explicitly says that warranty is voided if wrapped.. wanted to wrap mine
Old 09-27-2013, 04:09 PM   #190
blkfwlr
Drives: 07' Yaris Sedan
Hey, question about installation. It is possible without jacking up the car? People say they think you can, but can I? Want to install it today, but have no jack stands, unfortunately.
Blake
blkfwlr is offline   Reply With Quote
Old 09-27-2013, 04:11 PM   #191
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Possible? Sure.
PITA? Definitely.
Old 09-27-2013, 04:16 PM   #192
blkfwlr
Hm, I guess i'll just go for it. I'll have a person to help me, hopefully works out.
Old 09-27-2013, 05:23 PM   #193
The flange bolts from header to downpipe are only accessible from below. I don't know about you, but personally I cannot fit under the car if not raised.
Old 09-27-2013, 06:00 PM   #194
blkfwlr
I'm thinking to drive the front of the car on a curb just enough, so it would be sitting over the concrete, on the grass. Then I can slide underneath and hopefully reach the bolts still. Or is there a reason why this is flawed ?
Won't be on grass, just concrete. Going to do tomorrow morning.
Old 09-29-2013, 08:51 AM   #195
tooter
play every day
tooter's Avatar
That's a very clever idea!
If you can, post some pics of your installation.
Greg
Old 10-07-2013, 09:27 PM   #196
Neurotic Hapi Snak
Drives: 2011 Yaris 3dr
Is there a reason you don't put the heat shield back on? You'd think you'd want to, to keep your engine bay cool and exhaust header hot.
Neurotic Hapi Snak is offline   Reply With Quote
Old 11-16-2013, 10:36 PM   #197
catliektheif
catliektheif's Avatar
Drives: 2010 5 Door
I just installed mine yesterday and i LOVE it. it was a PITA to take out the stock header without a 12mm deep socket.. so if you are thinking of getting the dc header make sure to get one! I ended up going to the store to pick one up when i got to the last bolt.. lol. No CELs and no leaks! Definitely recommend it.
I have an afe short ram, trd axleback, MI pulley and I'm an AT. I definitely feel a difference and getting to 60-70mph is like butter.
lol okay
Old 04-18-2017, 10:28 AM   #198
kappa_md
Drives: Yaris RS2 2012
TRD made a 4-1 header (exhaust manifold) for the Vitz 1NZ-FE.
kappa_md is offline   Reply With Quote
