#2287 |
Roadrunner Jr.
Tell us more!
And I thought I had the cool project with vertical tri amping!
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#2288 | |
D.
. CLA 250, 4MATIC |
#2289 |
A little bit about "CENTER IMAGE-STAGE WIDTH-STAGE HEIGHT Relative to speaker Location!
![]() D.
. CLA 250, 4MATIC |
#2290 |
![]() ![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: Sep 2012
Hi D, I was looking over the image when you sound deadened your doors, did you keep the plastic cover that was initially on there? I was going to install new speakers and eventually deaden the doors - should I keep the plastic covering?
#2291 | |
It's a moisture barrier. (like a transparent plastic bag) The treatment on the doors is on 3 sides, inside of the door (outer skin) then the inner part (that holds the panel) and the Panel it self. I check once in a while for water and every thing looks good. D.
. CLA 250, 4MATIC |
#2292 | |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
those plastic films are actually for soundproofing |
#2293 | ||
. I'll be installing my speakers, along with my auto locks/windows at the same time. I'll have to hold off on removing the plastic for good until I get the proper material. Thank you for your quick reply!
#2294 |
What is "TOO MUCH" Bass? for SQ
D.
. CLA 250, 4MATIC |
#2295 |
RTA...? Real Time Analyzer
A tuning tool? or...? D.
. CLA 250, 4MATIC |
#2296 |
Roadrunner Jr.
Tuning tool most definately.
Did you have something else in mind?
#2297 | |
Pictures below: ![]() D.
. CLA 250, 4MATIC |
#2298 |
i6SW hold on tight! here it comes a 14 Years old 10" solo-baric!
I know this is not apples to apples, but I feel the need to compare and experiment. so here is my test box! (it's snowing any way lol) - Same power and source - Box is twice as big or about the same as (2)i6SW that I'm going to try later on. - 10" sealed box against 6.5" vented box - 14 years of technology Tomorrow is the big test. ![]() D.
. CLA 250, 4MATIC |
#2299 |
Roadrunner Jr.
D,
You know if you we're out here we'd work the 3055 and get you set up... I'm interested to hear your impression on the solo...the old rounds are some of my favorites. Gotta round off those edges...have a table router?
#2300 | |
7 years ago... I would be knocking on your door right now! D.
. CLA 250, 4MATIC |
#2301 | |
D. ps.. no table router )o: .
. CLA 250, 4MATIC |
#2302 |
Roadrunner Jr.
If I didn't have the compressor and the tank in the trunk along with the amps, I'd work another Solo D 15"...
You know...I might have to think about this for a little bit. Those Solo D 15s only need a cube and a half...no no...It's better if I don't. I still have that ML3800 sitting up in the spare bedroom that I have the custom trunk enclosure for. If I want a 15" woofer, I've got an amazing one already. Sorry, fleeting moment of weakness for the old solos.
#2303 |
I'm Impressed by...
How good the little i6SW is! versus the Solo-B 10"! D. .
. CLA 250, 4MATIC |
#2304 |
i6SW against Solo-Baric 10D - Power was 400 watts RMS
Enclosure i6SW wins, it's almost half of the Solo-10 (.35cf vrs .66cuf) In Car SPL goes for the Solo-10, Yes the bigger the better, but my ears hurt and honestly I just couldn't listen for my 3 hours commute and enjoy my music the way I do with the i6SW, in other words the Solo-10 for me is overwhelming Tonal balance: if the volume is from Low - Moderate - to High... the i6SW it's my favorite, now if I cranck it all the way up to MAX VOLUMEN... the Solo-10 WINS. (max volume is 2 or 3 clicks before distortion) Low frequency extension At low-Moderate volume the i6SW takes the lead, At Max Volume the Solo-10 wins Clarity at high volume (high volume not max volume) the i6SW takes the lead. Clarity at low volume, there is some thing magical about the i6SW that makes me smile. Impact - Both are good Overall sound quality - 2 thumbs up for the i6SW! I don't know what it is, maybe because it fires forward deep into the fire wall, but the big difference is the i6SW hits my chest, and the Solo-10 hits my ears and my head. I have a little cold and stuffy nose, so maybe that explains the ears, but I'll keep the Solo for a couple more commuting days and then report back, but ... If Had to buy one between these 2, I wouldn't think twice... the i6SW is the ONE! Next step!... lets plan on doing a second box for a second i6SW and see/feel/hear what happens! The never ending story! D.
. CLA 250, 4MATIC |
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
