![]() Drives: Yaris s Join Date: Jun 2012
Hid kit on 07 s sedan
Hi everyone I'm having a lot of difficulty getting hids to work. I've gone through several sets of h4 bulbs and have yet to have 1 ignite. This is extremely frustrating! Help! Thanks
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
try reversing positive and negative for the lo beams
#3 | |
USAF_SrA_E-4
This worked for me
Not quite a noob
I went through a lot of trial and error, and a lot of asking CTScott what I was doing wrong - something to do with the lights are operated in reverse: so I guess there's a constant current to keep the lights off, and when you want the lights on the current shuts down.
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
You can flip the connector that going into the ballast ..., on my case, using the morimoto h4 harness, I switched the blue and the white wire from the 3 prong to work... We have the thing called " the ground switch"
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
I had a problem with mine too but I am a wiring noob and can't even tell you what was wrong lol. Since I got them working I have had no problems.
#9 | |
Pirate Yaaaaris
Drives: '00 Toyota Celica GTS 6MT Join Date: Aug 2009
The high beam lamp will not illuminate in the cluster because the current is different, but if you have bi-xenon headlights, they should still ignite. If you replaced it with a single bulb xenon kit, there are no highs to ignite and thus you no longer have high beams at all. -C
Georgia Bulldogs! ![]() '09 Yaris LB 5MT Sold. |
| FS:35w HID KIT from REALTEK 8000k | wowitswil | Items for Sale by private party | 4 | 01-14-2010 02:28 PM |
| HID Kit | ecmiyake | DIY / Maintenance / Service | 5 | 12-12-2009 05:21 PM |
| What is the best HID kit ? | waka | General Yaris / Vitz Discussion | 1 | 12-03-2009 07:49 PM |
| To put on PnP HID kit without retrofit, Yes or No? | mr.white_hb | Cosmetic Modifications (Exterior/Interior) | 3 | 09-20-2009 08:43 PM |
