Old 01-06-2013, 11:09 PM   #19
discomark10
Drives: 02 Yaris 1.5 T-sport
reguarding the larger turbo, a bigger turbo will move more air which can be controlled by the wastegate
discomark10 is offline   Reply With Quote
Old 01-07-2013, 10:08 AM   #20
^ And creates more lag. The turbo should be matched to desired horsepower. If you aren't going over 200-250, a GT25 is perfect for this motor.
I have a GT28, and it takes about 500-600 more rpm to spool up than the GT25 did.
Old 01-07-2013, 01:20 PM   #21
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
??? dont think i mentioned anything about a larger turbo on the last post.
taKuto is offline   Reply With Quote
Old 01-07-2013, 11:59 PM   #22
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
i removed the greddy kit and replaced the manifold / down pipe, go find a used
gt25 from a nissan sr20. i found mine for under $100 (if yours doesnt suit it.
and its in very decent shape. has a .68 a/r for the exhaust which is a very nice balance for the size and car.
the compressor housing is also a nice .8 a/r bigger turbo for a 1.5L but
defiantly not small.
the greddy kit would still push 7psi at read line but the
manifold / turbine housing was so small it choked the exhaust and could move
enough air through it. pics of setups. ignore the dc in the middle.
ps these kits
are for an xb and used on an 02 echo sedan.
Scubaru Steve is offline   Reply With Quote
Old 01-14-2013, 09:34 AM   #23
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Where did U find that manafold and downpipe? Those look nice. Does your turbo clear the a/c lines? On my yaris they come out of the fire wall directly behind the valve cover.
pimp my yaris is offline   Reply With Quote
Old 01-14-2013, 09:39 AM   #24
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
They're OBX
Old 01-14-2013, 05:53 PM   #25
discomark10
That's the main reason I'm not going to turbo myn! I've even got a suitable turbo in a box.. just dont want to lose the ac
Old 01-14-2013, 06:36 PM   #26
You didn't; but discomark did, and I posted right after him in response to his post.
Old 01-14-2013, 06:37 PM   #27
My turbo cleared all the a/c just fine. I removed the a/c when I switched to a standalone management (because it was problematic to have the EMS control the a/c).
Now that we have the AEM EMS + Boomslang harness option (running the EMS as a piggyback), I wish I could have done that.
Old 01-14-2013, 08:05 PM   #28
discomark10
interesting... what header have you got?
Old 01-14-2013, 09:39 PM   #29
pimp my yaris
C'est la vie
This is the manafold Cali Yaris is using. I have the same one on my car. It does clear the a/c lines with plenty of room.
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
Turbo kit Brainstorming Gideon Forced Induction Forum 16 04-19-2009 12:54 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? ceboyd In Car Entertainment + Electronics (audio / video / alarm) 7 12-08-2006 02:13 PM
