![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
Fog light icon/indicator in cluster
Hi Scott/AbsolutelyRed/anyone, mine is a 2012 sedan (although technically this is not the same as a 2012 hatch), what is the way I can find out that i have a foglight switch icon on my cluster? or would you know right off the bat if i do or don't?
Here's what I have, an aftermarket factory installed Esuse fog switch on the left lower dash (which Toyota got me believing they are Stanley (or Koito at least)), beside where the power mirror switch is. Mine is a TOTL 1.3L while the TOTL 1.5L variants here have an integrated foglight switch on the stalk but is also coupled with a slightly different cluster (optitron). |
The 2012 sedan is really still a second gen Yaris, so the factory wiring is not as complete as it is with the third gen Yaris.
If you have aftermarket fogs installed they are likely installed completely independent of the OEM wiring, which is why your indicator on the speedometer does not light up. It is almost definitely present, but unless the OEM fog light relay wiring is used to drive the fogs, it doesn't light. If you do some searching, there is a thread on here where I explain how to connect the wiring from the aftermarket fogs to turn the indicator on.
Oh ok. Will do the search. Thanks scott. I am hopeful mine does have that indicator on the cluster...
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| Original tail light without rear fog light for Yaris 3dr 2009-2011 | Ot_tO | Cosmetic Modifications (Exterior/Interior) | 9 | 08-07-2012 04:27 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| test fit 06-07 Yaris 4 door fog light | winson | California | 15 | 01-13-2009 08:25 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
