![]() Drives: 2011 toyota yaris Join Date: Jan 2013
help me
guys, please help me. my car consumed a lot of fuel. what should i do? thanks
やりすぎだ~
Add more fuel.
hi
I definitely filled up the fuel, if not filled, my car definitely will not turn on.
When someone loves you, the way they say your name is different. You know that your name is safe in their mouth. |
Did it just suddenly start using more fuel than usual? How many miles do you have on the odometer?
Check your tire pressure, making sure that all the tires have even psi and that it's set to at least 32 psi each. Check your air filter and replace if it's dirty. Let this tank of fuel go down to about 1/4 tank (two bars left), and refuel at a different gas station from the one you filled up and noticed the higher consumption. It could be that you got some bad fuel. If it still consumes more fuel than usual, have your alignment checked and corrected if needed. If you have high miles, you might want to change your spark plugs. |
Also note that environmental factors can affect gas mileage, such as elevation, head wind, and temperature.
Nothing beats a Toyota!
Drives: 2013 Yaris 5 dr liftback Join Date: Jan 2009
IS this a joke thread question? All cars use fuel. It is caused by usage. Will happen every time.
Big Dave Indianapolis, IN Synthetic Oil....its in my car.....for at least 10,000 miles! ![]()
I don't think the OP is trying to be a troll. I doubt English is his native language. I think he is just trying to say that he isn't getting very good gas mileage. I just couldn't help but laugh re Yarisugi's sarcasm.
How much fuel is the car using, what car is it and what engine?
If its the 2011 it should be still under warranty
Have Yaris will travel.. |
