My Face Is Ridiculous
Drives: 2010 Toyota Yaris 3dr LB Join Date: Dec 2011
Blackout section between upper and lower grilles, opinions.
I want some opinions before I actually do this. I like the look but I'm just not sure. Take a look at my quick photoshop and tell me what you think.
and with yellow fog lenses for good measure
If the lower grill was just a bit narrower...maybe. As you have it laid out....not a fan.
personally, I dont like the look. the grills don't match up enough to make it "flow". But its your car. If you like you, you should rock it!
![]() ![]() ![]() Drives: 2010 5 Door Join Date: Feb 2011
this is an old picture of mine, which ive redone since then but the bottom grill i left the same. personally i love the way it looks and Id recommend it. i used plastidip but it took a couple tries to get it right, especially at the upper grill because of how it curves. you could use plastidip too adn if you end up hating it peel it right up! just remember to pull the tape before each coat dries and re-tape. its a pain but its the only way to get a clean line. like this but i changed it since then so the curve at the upper grill doesnt look so awkward.
lol okay |
can you repost the pictures? they're not showing up. thanks!
lol okay |
![]() ![]() Drives: 2008 XP9 by Sparco Join Date: Nov 2011
Did you try it out?
thinking of doing the same on my red '08 LB. 08 should make easier lines I guess since the top grille is wider. |
#9 | |
play every day
![]() I was also considering the same idea, but my vents also have slanted edges even worse than yours and it doesn't look right if they're not vertical. That's one of my biggest laments on the 2012's, that they don't have rectangular vents.
#10 | |
play every day
![]() ![]() It's because the black follows your vertical hood lines. 2012's don't got 'em.
![]() ![]() ![]() Drives: '10 Yaris LB Polar White Join Date: Oct 2010
I have always been impressed by your little detail upgrades over time. |
thanks!!
lol okay |
| Pics of upper & lower grill mods + more | minired5stby | Cosmetic Modifications (Exterior/Interior) | 33 | 10-28-2012 03:32 PM |
| Painting plastic mesh? Upper and/or lower. | wholenizz | Cosmetic Modifications (Exterior/Interior) | 2 | 05-20-2010 08:22 AM |
| In need of upper and lower grilles and upper grille cover | bam2626 | Items for Sale by private party | 2 | 06-25-2009 10:34 PM |
