Old 03-29-2007, 09:44 AM   #19
nurburgring
ringmeister
nurburgring's Avatar
Drives: YARIS 1.5
Originally Posted by largeorangefont View Post
If you are getting a setup similar to what I have then it would be wise to follow my reccomendations. Are you going to lower the car?
Black's car is stock height. That is why it dosent rub. He would have rubbing problems if his car was lowered.
The rubbing on my car is minimal, and I am lowered fairly agressively. 1.7 inches all around. If you do not lower it as much as me you should have no problem at all. If you do lower as much as me, you should see less rubbing than me based on your offset.
Thanks for your feedback. You used to say your tyre rubs on the inner guard of the wheel well. Am I right to say, u discovered that the rubbing actually occurs on the inner side of the fenders instead ?
I'll be doing NF210s.
nurburgring is offline   Reply With Quote
Old 03-29-2007, 10:16 AM   #20
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Correct. I thought it was on the inside, but jacked the car up this weekend and looked and it is rubbing on the outside. It is about a 1 inch by 2 inch section where it is hitting, not much at all. Woth NF210s you should be fine.
Speaker Spacers - Pi**in me off!!! hasher22 Cosmetic Modifications (Exterior/Interior) 4 08-12-2006 11:28 PM
