Old 01-03-2013, 12:17 PM   #1
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Great Oil for cheap!
Hi all, I'm new to Yaris, but a 30 year plus Toyota owner.
I'm sure this is nothing new, but I found some great oil for $5.4 per Qt.
Mobil1 extended service @ Walmart for $27. per 5 qt jug.
Regular auto parts stores are selling this stuff for $9.99 per qt.
http://www.mobiloil.com/USA-English/...nce_5W-30.aspx
UberSilver is offline   Reply With Quote
Old 01-06-2013, 11:19 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
3k/3 month interval:
Conventional Oil 10w-30 (40qts needed for 25k miles)
@ $3.00/qt * 40 = $120.00
8 Standard Filters
@ 6.00/filter * 8 = 48.00
Total: $168.00
AMSOIL 25k/1 year interval:
AMSOIL 10w-30 (5 qts needed for 25k miles)
@ 7.35/qt * 5 = $47.75
1 EaO Filter
@ 18.30
Total: $55.05
Savings: $112.95 annually
Even if you only drive 12k miles per year you are saving just in oil/filter costs not to mention the following benefits:
- Easier cold-temp starting
- Improved fuel economy over time
- Cleaner running engine
- Cooler running temps
- Should experience more power/throttle response
- Less engine wear
- Longer intervals between changes which means less inconvenience of the car being at the shop
Old 02-07-2013, 10:56 PM   #3
Hershey
Shell synthethic for $3.33 a quart ( before tax ) . Will be posting an used oil analysis of SHELL synthetic 5w-20 from the '08 sedan within a few weeks .
Old 02-08-2013, 10:37 AM   #4
UberSilver
UberSilver's Avatar
That would be a good deal if it were a true synthetic(group 4 or 5), instead of a hydro cracked group 2~3.
Still most likely good oil.
Old 02-08-2013, 02:59 PM   #5
+1 for Amsoil. I've been using them for at least 4 years (annual changes only, drive 12k-15k miles a year). Best stuff! I did a compression test last year around this time, and had around 78k miles on my car. Got 204 psi (give or take 2 psi) for each cylinder.
Natural Gas Transportation - Why Not? Kal-El Off-topic / Other Cars / Everything else Discussions 1 03-20-2011 01:12 PM
DIY Oil Pressure Gauge Install LtNoogie DIY / Maintenance / Service 13 11-20-2009 04:13 PM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
Question About Engine Oil Kaotic Lazagna Off-topic / Other Cars / Everything else Discussions 21 08-29-2009 03:08 AM
embarrassingly bad mileage... REALLY XYaris Fuel Economy Forum 83 05-05-2009 04:47 PM
