Drives: Bog Standard Yaris Join Date: Feb 2013
Driver Side Wiper Issue
Hi All,
This is my first post as I've search the web and couldn't find an answer to my question, so thought I'd register here and see what I could find out. Basicly I have a small issue with my driver side wiper blade. The blade keeps hitting the passenger side on the down stroke as it reaches the bonnet. The driver side blade also now leaves a bigger gap between the edge of the windscreen and the piller. This started after some snow fall a few weeks back, and that build up of snow you get at the edge of the windscreen. Its almost as if the wiper is out of sync a little. Hope this makes sense. Any help would be greatful, as the constant 'thump, thump' of the of the wipers hitting each other is starting to grate! |
Are you sure you have the right size wipers?
Maybe one of them got bent out of alignment and a bit of gentle bending is required to get them back into alignment
Have Yaris will travel.. |
The wiper arm has slipped on the mounting spindle.
Pop the black plastic cap off of the wiper arm base, remove the nut, lift off the arm and put it back on in a slightly higher position. Tighten the nut back on and replace the plastic cap.
| Wedge Engineering driver side seat bracket | Benedict | Items for Sale by private party | 1 | 02-11-2013 09:17 AM |
| DIY: Adding LED turn arrows to side mirrors | my2sense | DIY / Maintenance / Service | 10 | 05-28-2012 02:16 AM |
| Wiper blades .... | Lafiro | General Yaris / Vitz Discussion | 81 | 02-02-2012 06:54 PM |
| WTB Driver side headlights for 08 LB | Yarice | Willing to Buy by private party | 0 | 04-12-2011 02:03 PM |
| Rear wiper: EZ mod so it pulls back all the way | joelitton | Cosmetic Modifications (Exterior/Interior) | 10 | 10-22-2008 10:30 AM |
