Old 02-25-2013, 08:03 PM   #1
kwkshft
kwkshft's Avatar
Drives: 09 Yaris S 3drHB
Send a message via Yahoo to kwkshft
Can I use 14 inch wheels in H stock AutoX?
Well, a set of used Hankook Ventus Z214 C71 just rolled into my garage 205/55X14. Wondering if I can use these in H Stock AutoX. My 2009 hatch has TRD rear sway bar and TRD exhaust, that's it. If so, what width and offset is permissible? Thanks.
kwkshft is offline   Reply With Quote
Old 02-25-2013, 08:12 PM   #2
justjesus
justjesus's Avatar
Drives: 2008 Liftback
only the stock width is allowed.
offset has to be within + or - of 1/4" from stock
Old 02-25-2013, 08:47 PM   #3
Steve35
Steve35's Avatar
Drives: 2008 HB
here is the wheel rule on page 75 of the 2013 Solo rule book
13.4 WHEELS
Any type wheel may be used provided it complies with the following: it
is the same width and diameter as standard and as installed (including
wheel spacers if applicable) it does not have an offset more than ±¼”
(±6.35mm) from a standard wheel for the car. The resultant change in
track dimensions is allowed. Tire pressure monitoring sensors may be
removed.
Wheel spacers are permitted, provided the resultant combination complies
with the offset requirements of this section. Wheel studs, lug nuts,
valve stems (including pressure-relief types), and/or bolt length may be
changed.
Vehicles equipped with rims having metric specifications may use alternate
rims as determined by using the following procedure:
Diameter: converting the metric measurement to inches and using
the nearest smaller inch diameter rim.
Width: converting the metric measurement to inches and using the
nearest smaller ½” (12.7mm) width rim. Offset and track must still
comply with the requirements of this section.
Steve35 is offline   Reply With Quote
Old 02-25-2013, 09:08 PM   #4
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
This is probably the best resource for determining what puts you in which class. Keep in mind that these rules are generally only enforced at the regional/national level, and your local events may choose to forgo them.
http://scca.cdn.racersites.com/prod/...lo%20Rules.pdf
Which means using those wheels puts you in at least STF.
Old 02-25-2013, 09:52 PM   #5
racerb
What size wheels did your car come with stock? Most tire dealers list a 14" or 15" wheel as standard equipment, so the standard 14" steelies would be fine! If your just running with your local club, something like these from Discount Tire Direct will work for Stock Class....http://www.discounttiredirect.com/di...5.5&vid=015624
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 02-26-2013, 04:34 AM   #6
kwkshft
kwkshft's Avatar
Thanks for the info guys! So it looks like 14X5.5 with +30 to +40 offset will work. Any recommendations on tire pressures?
09 Yaris S
85 Corolla GTS
Old 02-26-2013, 11:40 AM   #7
Steve35
Steve35's Avatar
Drives: 2008 HB
I'd start in the high 30's, say 38 front and rear and adjust from there.
see this link from Tire Rack
http://www.tirerack.com/tires/tirete....jsp?techid=58
good luck and enjoy the extra grip!
Steve
Old 02-26-2013, 05:18 PM   #8
justjesus
justjesus's Avatar
the guys over in HS here run higher than 40 on Hooziers. One dude ran even higher in the rear, about 50+ if I'm not mistaken.
I put higher pressure in Garm's rear tires (higher than what he normally runs), and coached him a tad, and he dropped a good amount in some autoX runs. Total of almost 2 seconds on sub 50 sec course.
Old 02-26-2013, 06:00 PM   #9
Mmm, 14" r-comps on stock steelies
Old 02-26-2013, 06:12 PM   #10
racerb
Be very careful on R-Compound tires with stock struts and shocks, these tire grip so well they can create bicycling on tighter auto-x courses. Work up to your limits until you are ready for suspension upgrades and you will be much happier in the long run. Also a very good way of checking for proper tire pressure is to put a couple 1"-2" long lines of white shoe polish on the tire shoulders. It's very easy, if your scrubbing the entire line off, then up your pressure, if your not even touching these lines, lower your pressure, it's that simple. Oh and some crash bolts for negative camber in the front suspension from Micro Image, will be a huge improvement!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 02-26-2013, 06:42 PM   #11
justjesus
justjesus's Avatar
hehe
i like that red car with the r comps!
Old 02-27-2013, 05:43 PM   #12
kwkshft
kwkshft's Avatar
racerb
Can you explain what you mean by bicycling? Thanks
09 Yaris S
85 Corolla GTS
Old 02-27-2013, 07:12 PM   #13
justjesus
justjesus's Avatar
im guessing he means TWO wheel action
Old 02-27-2013, 07:33 PM   #14
bicycling = 2 wheels
Old 02-27-2013, 07:33 PM   #15
I love it when you talk dirty.
Old 02-27-2013, 08:39 PM   #16
racerb
Yeah I have seen it on several occassions where cars would actually get up on two wheels due to higher grip than suspension could handle. There are lots of videos of it on Youtube, check it out to see what I mean!
Here is one example...http://www.youtube.com/watch?v=A0hTl78eaI8
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 03-06-2013, 05:44 PM   #17
markitect
Drives: Yaris
If you need more wheels rolling into your grarage I have stock steel wheels with 205/50-15 falken azenis 615's on them. I was planning on getting them out to measure tread to post up to sell.
markitect is offline   Reply With Quote
Old 03-06-2013, 06:55 PM   #18
wider stock wheels ? larryn2o Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 01-24-2011 09:49 AM
Converting from Custom Wheels back to stock!!! daddz07 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-23-2010 08:45 PM
Stock Wheels 15' and Black Stock Hood (SoCal) White Yaris Items for Sale by private party 9 01-07-2010 12:39 AM
changing stock wheels? bribri Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 06-30-2009 10:30 PM
FS: Stock steel wheels and hubcaps letstry1234 Items for Sale by private party 0 06-22-2009 12:31 PM
