When should PCV be changed?
Just that? What are the indicators? If the PCV connection or itself isn't working right, what are the signs? Check engine light? Hissing sound? Rough idle when in stopped with break on in drive?
Thanks for any thoughts. Pat |
Thoughts?
![]() ![]() Drives: 08 Yaris AT, 350Z GT MT Join Date: Feb 2013
I replaced the one in the car as a part of the 80k miles maintenance I'm doing.
It's so cheap I can't think of why didnt do it at 50k. |
Ok...but why? I am curious to know what happens when it stops doing what it was designed to do...which I am not sure of either.
![]() Drives: 2010 Join Date: Oct 2012
You can easily test it. Just remove it, and give it a shake. If it doesn't rattle, it's gunked up - replace it. They are inexpensive locally or on the 'nets. You'll swear your car will run smoother and you'll have better luck with traffic lights.
Keep us posted! |
@cdilmore - thanks so much!
By chance do you know the ft/lb torque spec on the PCV for when I replace it? |
![]() ![]() Drives: Yaris Sedan Join Date: Apr 2012
According to the manual, 20 ft lbs
I would like to also add, 117k miles and the PCV wasn't gunked up at all! :) |
@Yarflana,
Were you successful in changing the PCV valve? I'm sensing that Congrats are in order! |
Thanks but not yet...hit a snag with the brake line yesterday so didn't get to it...perhaps next weekend...thanks for the encouragement...I think it will be in good shape.
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
| PCV Valve Replacement | devinlamothe | DIY / Maintenance / Service | 27 | 03-16-2013 11:06 PM |
| So when DOES the transmission fluid need to be changed | dutchy999 | DIY / Maintenance / Service | 12 | 09-06-2011 05:18 PM |
| changed belt,got scan code POO1O | yaris9876 | DIY / Maintenance / Service | 10 | 12-17-2009 10:31 PM |
| Has anybody Changed the Odometer in the HB | pp.sweet | DIY / Maintenance / Service | 2 | 08-21-2007 06:00 AM |
