Old 12-12-2012, 01:08 PM   #1
TOLMACH
Drives: soarer
Scion XB / Yaris Blitz SC compatible?
Same engines.. would there be any differences in supercharger sets?
Thx
P.
Old 12-12-2012, 01:17 PM   #2
TOLMACH
Drives: soarer
The vendor can sell it for around 1500
http://www.ebay.com/itm/Scion-Xa-Xb-...item2578a797f6
BAsed on what I am reading right now.. may be not totally compatible
Old 12-12-2012, 01:21 PM   #3
Focus_Sh1ft
Focus_Sh1ft's Avatar
IIRC someone did this a while back and it did in fact need modification. Someone else will probably know better than me.
Old 12-12-2012, 04:25 PM   #4
I believe it was thebarber that had one on his. The xA/xB has a different setup throttle body, and the blitz kit for it is different, as the intake to it has a flexible coupling to a second metal tube that the throttle body bolts to.
Old 12-12-2012, 04:46 PM   #5
TOLMACH
Drives: soarer
Thank you!
I am not even impressed anymore.. We just assume that you know everything ))))
Old 12-12-2012, 06:12 PM   #6
I would guess the fuel controller would be a little different as well, and I know the pinouts on the xB ECU are different.
Old 12-12-2012, 07:24 PM   #7
TOLMACH
Drives: soarer
^ Thanks
Old 12-12-2012, 09:39 PM   #8
The fuel controller is identical, but you would need to follow the Yaris installation directions, since as Garm mentioned, the ECM pinout is different.
Old 12-12-2012, 09:55 PM   #9
throttle body mount is different, you'd have to fab an adapter plate to make the yaris throttle body (4 bolt) fit the echo/xb throttle body setup (3 bolt)
iirc, the angle is a BIT different as the xb and yaris have different airbox setups...not a big deal if you're running a short ram, though
wiring, as mentioned, you'd have to use the blitz instructions for a yaris
and i think you'd have to find a new belt length since the xb runs a stepped crank pulley
**ive OWNED a blitz and greddy s/c for an xb1, but never put it on a car...i ended up finding a yaris blitz kit for mine**
Old 12-12-2012, 10:49 PM   #10
vten
I believe mine is a retrofitted from the Xb as well, but mine is modified to have a fixed pulley.
other than you need to fabricate the throttle body mounting, it's pretty much plug and play, but I dont use the supplied fuel controller, Im using AEM FIC instead
Old 12-13-2012, 01:58 AM   #11
TOLMACH
Drives: soarer
^ Thanks guys!
Old 12-13-2012, 06:38 AM   #12
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I wonder also if the adaptor that tooter made for his intake manifold would work on this intake and I am sure tooter would cut you a deal for just that.
Old 03-17-2013, 06:27 PM   #13
TOLMACH
Drives: soarer
Update:
Started installing my kit yesterday. I am slow but managed to make some progress )) Mechanical part is circa 90% complete: the kit is installed though not wired. The car starts, idles kinda rough (does not stall, also no CELs) but she always does it after the battery is disconnected.. looking good so far. One of pics shows tooter's adaptor between the intake and the TB. I might also need to play with belt tension - I am hearing some sort of squealing as engine rpm increase.
http://photo.qip.ru/users/tolmach/96608749/130266829/
Tooter's adaptor
http://photo.qip.ru/users/tolmach/96608749/130266837/
http://photo.qip.ru/users/tolmach/96608749/130266839/
Old 03-17-2013, 06:51 PM   #14
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Excellent! We had actually talked about this in a "Blitz + 1ZZ TB" thread recently. I would actually prefer to have the xB upper intake side, so that I could make a cleaner connection to the throttle body after the flex coupling.
Old 03-17-2013, 06:56 PM   #15
TOLMACH
Drives: soarer
^ Tooter's adaptor is awesome. It is not cheap but imo is worth the price.
Old 03-17-2013, 07:55 PM   #16
CrankyOldMan
Agreed. There was some quality engineering involved in the development of that part.
Old 03-19-2013, 03:07 PM   #17
TOLMACH
Drives: soarer
Just got p0441 CEl
Kinda suspect it deals with the black box with two rubber hoses mounted on top of the air filter tube (tube between the filter and intake manifold).. I forgot to install one of the tubes (I do not have enogh nipples on my intake manifold) - will probably have to splice into one of the vacuum tubes between around the intake manifold.
Old 03-19-2013, 04:05 PM   #18
Just got p0441 CEl
Yes. 0441 is an issue with the purge VSV, which is that little square box.
Factory OEM Scion T1814 Pioneer Deck in the Yaris PICS auxmike In Car Entertainment + Electronics (audio / video / alarm) 20 08-02-2012 11:30 PM
Putting scion seats in a yaris xnamerxx Cosmetic Modifications (Exterior/Interior) 3 03-09-2010 12:17 AM
