Old 01-16-2013, 04:01 PM   #19
06yarishb
Drives: 2012 Yaris HB LE
There is none on the 2012. The fog light relay is built into the body ECU.
To see if it is enabled on your car, you can jump pin 3 to pin 4 on the headlight switch connector D106. Pin 3 will be brown or green (depending on if you have the OEM alarm) and Pin 4 will be green.
Jump those wires and have the ignition on and the headlight switch in the low beam position. If the fogs don't light then the relay is not in there. For the 2nd gens for instance the integrated relay for the power windows and locks is not present on cars that were not built with them (and there are different part number for the body ECU).
Attachment 48579
Sorry stupid question: what do you mean by jump pin 3 to pin 4? Is that mean you connect the pin 3 to pin 4? just got a 2012 yaris hb le and want to add the fog light on. Thanks
06yarishb is offline   Reply With Quote
Old 01-16-2013, 04:05 PM   #20
With the 2012's to add fogs you simply install and connect the foglights on the front bumper and then install a switch that connects the wires in pins 3 and 4 together (i.e. jumps one wire to the other).
Old 01-16-2013, 10:00 PM   #21
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
Remove the lower steering column cover.
Locate the connector shown in my picutre.
Tap the fog switch wires, one to the violet, and the other to the green wire.
The two by themselves.
You can alternatively not use a switch, and jump the two wires, they will go on, and stay on when the headlights are turned on.
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 01-25-2013, 08:11 PM   #22
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
Looks like I will be getting a micro image fog light kit......Toyota fog kit is warranty replace only. PLUS get this: parts department showed me on screen that mid level LE trim does not/can not have fog lights installed from factory or aftermarket.....lmao......he sighed and laughed too, as that is what the screen inventory stated.....
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 02-23-2013, 01:04 PM   #23
oohcory
Oohcory
Drives: 12' Yaris 2dr Liftback
Send a message via AIM to oohcory
has anyone with a 12' LE tried installing aftermarket fogs?
oohcory is offline   Reply With Quote
Old 02-23-2013, 02:15 PM   #24
Yes. Besides Absolutely_Red, a few others have as well.
Old 02-23-2013, 10:50 PM   #25
Absolutely Red 12
Asshole
All that is needed from the kits, are the lamps, fillers, and switch.
2012s have the wiring preinstalled.
As CTSott mentioned, the relay is integrated into the BCM.
You dont even need a switch!! If you want the fogs to always be on with the headlamps.
The lamps, if anyone is interested, are Camry interchange part numbers!!
Old 03-22-2013, 09:56 PM   #26
oohcory
Oohcory
I for the life of me cannot find this. All that's below my steering column is an airbag? I'm a noob, little help please?
Old 03-22-2013, 11:04 PM   #27
You are looking too far down. You need to remove the lower steering column cover to find that connector (which is at the base of the headlight switch).
Old 03-23-2013, 04:51 PM   #28
oohcory
Oohcory
Oh ok, is there a trick to taking it off? Or is it just the three screws and pop her off
Old 03-23-2013, 05:00 PM   #29
Just the three screws and squeeze it by the seam to separate it.
Old 03-23-2013, 05:29 PM   #30
oohcory
Oohcory
Thanks! I jumped it, everything's golden!
Old 09-01-2013, 02:56 PM   #31
geoded
geoded's Avatar
Drives: Yaris MY2012 - 1ND-TV
Until after someone installed fog lights on 2012 Toyota Yaris? Pictures?
geoded is offline   Reply With Quote
Old 09-02-2013, 01:07 PM   #32
geoded
geoded's Avatar
fog fuse
fog fuse
Old 09-02-2013, 01:13 PM   #33
geoded
geoded's Avatar
@Absolutely Red 12, You understand that you are including in FR FOG fuse?
Old 05-16-2014, 01:57 PM   #34
geoded
geoded's Avatar
OK. DISREGARD my last post.
I forgot to turn on the ignition DOOOOHHH!
Jumping the purple and green wires at 3&4 made the fogs go on!!
The light on the dash also works!!
Time to get some taps, and wire the switch.
Now taking this one step further, how do I make it work with park, low, high.
CT Scott, thank you for the help, also in advance!!
I'm sorry, but, I do not work. I have Yaris 1.4 d4d, 1ND-TV, I put the fuse, I jump the wires at 3 & 4 made ​​the fogs not go on! I started the engine and the fogs not go on. What can I do? Any idea?
Old 05-16-2014, 02:12 PM   #35
Jumping brown in 3 to green in 4 is correct for your TMMF built Yaris. The headlight switch must also be on and in low beam mode for the front fogs to light.
Old 05-16-2014, 02:18 PM   #36
geoded
geoded's Avatar
Yes, I did but it does not work.
2012 Fog Light Kits TimmyTwo2 Third Gen Yaris General Discussion 4 10-06-2014 03:41 PM
2012 Fog lights FIY Absolutely Red 12 Third Gen Yaris General Discussion 1 09-17-2012 10:31 PM
2012 Yaris LB Fog Lights TimmyTwo2 Cosmetic Modifications (Exterior/Interior) 6 03-21-2012 04:54 PM
Need fog light switch and relay Jrilla DIY / Maintenance / Service 23 07-01-2011 11:12 AM
