Old 03-24-2013, 06:19 PM   #1
wildmongoose26
wildmongoose26's Avatar
Drives: 09 5dr Yaris
Blitz Fuel Controller Issue
Got everything buttoned up last night. Clutch engages, etc. Builds boost, no leaks.
At idle we run 14.5 A/F so that's normal.
The light on the dial lights up when we get into boost and not vacuum. Normal.
The light on the fuel controller box does not light up at all. Not sure if it is supposed to be on ALL the time or if its only supposed to come on while in boost like the light on the dial.
In boost in stays roughly around 14.5 but that is just in the air, not while driving.
Any advise?
Is the light on the fuel controller supposed to be on all the time?
Angela
Old 03-24-2013, 08:31 PM   #2
Any advise?
Angela
The light on the little switch assembly should light when the clutch is engaged by the fuel controller.
Old 03-24-2013, 11:11 PM   #3
wildmongoose26
But only when its engaged? Not constant?
Both the light on the dial and on the fuel controller box?
Old 03-24-2013, 11:50 PM   #4
My fuel controller doesn't have a light on it, just the dial does. And, the light on the dial just comes on when the SC is engaged.
Old 03-25-2013, 01:29 AM   #5
wildmongoose26
That light works. The A/F seems a bit off. Going to look at it a bit more tomorrow.
Everything engages, drove the car and A/F goes down to 12.5 after a little while. But its a dial type gauge from Glowshift so it may just react a little slowly.
Old 03-25-2013, 02:19 AM   #6
TOLMACH
Drives: soarer
Where is your sensor installed?
Also just curious where did you install the gauge itself?
Old 03-25-2013, 03:01 AM   #7
wildmongoose26
180 degrees from the stock o2 sensor and put the gauge under the HVAC controls
Old 03-25-2013, 07:52 AM   #8
Tima122
Drives: bB NCP 31 2005 y
Toyota bB
Tima122 is offline   Reply With Quote
Old 03-25-2013, 07:59 AM   #9
Tima122
Toyota bB
Splitfire
Injen
Old 03-25-2013, 11:12 AM   #10
wildmongoose26
I have no idea how the pictures are relevant
Old 03-25-2013, 11:45 AM   #11
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Now you know he's boosted too
Old 03-25-2013, 11:51 AM   #12
narrowband or wideband?
Old 03-25-2013, 12:22 PM   #13
wildmongoose26
Wideband
Old 03-25-2013, 02:36 PM   #14
TOLMACH
Drives: soarer
Thanks
My sensor is in the same location. You also seem to have found an interesting place for your gauge.
Old 03-25-2013, 05:09 PM   #15
Does 180 degrees mean the two sensors are pointing at each other in exactly the same place inside the pipe?
Old 03-25-2013, 06:25 PM   #16
wildmongoose26
Bot at each other. But in the same area of pipe yes. Too close would be weird an restrict air alot in that one place.
Old 03-26-2013, 11:20 AM   #17
wildmongoose26
Finished. Everything works. Correct a/f the dhole way under boost. Idle a/f is perfect. Engages when it should according the the dial. It was a wiring problem. Used t taps like it said to and they almost cute the wires to the ecu. Had a friend solder them and its perfect can't even tell there is any extra wiring!!
Old 03-26-2013, 11:37 AM   #18
1.5
Form>Function
1.5's Avatar
awesome great news. Lets see some vids now. Any plan for dyno/tune?
Blitz Fuel Controller Issue wildmongoose26 Forced Induction Forum 1 05-06-2013 06:31 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 04:34 AM
Blitz throttle controller 808_Yaris Performance Modifications 43 10-22-2009 05:36 AM
Blitz owners: fuel controller question s3r3nity Forced Induction Forum 28 05-30-2009 10:19 PM
