#19 |
None. There is just the switch, fog light relay, and if you have DRLs, the DRL relay is in circuit as well.
#20 | |
#21 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
this appears to have been the problem it wasn't making a good connection in it and kept wiggling lose. I also moved my ground to better location the other one was questionable. now to see if it keeps working or starts being fickle again.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| LF: Yaris switches | carrera2 | Willing to Buy by private party | 0 | 07-11-2009 05:10 AM |
| Power Window Switches | Stoln | Australia | 5 | 11-07-2008 09:02 AM |
