Old 04-08-2012, 08:33 PM   #1
yaris4062007
Drives: 07 BB yaris / 06 Mustang Gt
2007 yaris cv passanger axle and cardone select cv axle picture )
cardone select doesnt have rubber thing in the middle like the stock cv drive axle. Do I need it or not on cardone select.. thanx
yaris4062007 is offline   Reply With Quote
Old 04-08-2012, 08:39 PM   #2
yaris4062007
stock cv axle and cardone new cv axle
Old 04-08-2012, 08:45 PM   #3
yaris4062007
pic
Old 04-08-2012, 09:32 PM   #4
That rubber thing is a vibration damper. There is only one on the right (longer) drive shaft.
I am not sure how much of a difference you will feel without it, so I think I would contact Cardone to see if they intentionally leave it off.
Old 04-08-2012, 09:41 PM   #5
yaris4062007
i noticed stock axles are little bit heavier then cardone select. I am just going to install it and see if it makes difference or not.. do i need to lubricate the inner cv joint with transmission fluid or white litium grease. if yes where do i lubricate on inner cv joint thread with c-clip and outer cv joint thread. thanx :)
Old 04-08-2012, 09:53 PM   #6
The inner should be lubed with ATF. Just dip your finger in it and coat the spline and snap ring before you insert the shaft. The service manual doesn't indicate lubing the outer spline.
Old 04-08-2012, 09:54 PM   #7
yaris4062007
Got it, thank you ;)
Old 04-08-2012, 11:27 PM   #8
yaris4062007
Old 04-08-2012, 11:30 PM   #9
yaris4062007
picture of inner cv joint
Old 04-09-2012, 12:49 PM   #10
CoryM
Drives: 2009 5-door, 5-speed
As mentioned the rubber is a vibration dampener. You should not notice any problems with it gone.
A little late, but for the next person; Put a little lube on the area where the seal rides on the inner CV axle. This way your seals are lubed from the start. Also, I see in the last pic you have the sharp axle splines resting on the seal. The idea is to not touch the seal with the splines at all. If the seal gets even a small nick, it will leak.
I typically use a bungee cord or strap to pull the knuckle assy back so I can get a straight shot at the transmission with the shaft.
Cheers,
Cory
Old 04-09-2012, 02:13 PM   #11
auxmike
auxmike's Avatar
I had to pull my axels to do a clutch swap on a '97 Saturn. Had the whole job done and buttoned up. Next day the freakin' axel seal leaked at the tranny side. Smoke all over from the oil landing on the hot exhaust. I almost broke my hand with a 3ft. pry bar doing the job. I was fed up and that's the day I said... F' this,I'm buying a new car.
Thus the new Yaris back in '08.....
Old 04-09-2012, 02:45 PM   #12
yaris4062007
Is it hard to replaces seal if it leaks. My car does viberate inside maybe i need wheel alignment. Next time i remove the cv axle i will make sure to grease seal ;). Thanx for info. :)
Old 06-04-2012, 10:22 PM   #13
TRX
Drives: 2006 Toyota Yaris Hatchback
I wonder if these axles are the same for a 2007 HB with a 1.3L engine? I need to replace the LH on mine, but the dealer wants $800.00 bucks.
TRX is offline   Reply With Quote
Old 06-04-2012, 11:19 PM   #14
Do you have the 2NZFE or the 2SZFE and which transmission do you have?
Old 04-11-2013, 09:27 PM   #15
jayy
Drives: yaris
did you need to remove both balljoints to get at the axle? and how did you get the axle out of the tranny ? please reply i really need to replace mines, thanksss
jayy is offline   Reply With Quote
Old 04-11-2013, 09:34 PM   #16
You just need to remove the ball joint on the side you are working on. For getting the axle out, there is a lip on the inner cup that you push or pull out by.
The left side is trickier than the right, as you have to pull that one out using something like the Toyota SST shown in the top image. The right is easy in that you can pull it out using a large screwdriver and a mallet.
Old 04-11-2013, 09:57 PM   #17
jayy
Drives: yaris
i REAAALLY apreciate the reply, im planning on removing the lower control arm balljoint, will i be able to get the axle out just by removing the lower control arm? and can the outer joint be removed from the axle by pounding it out wit a brass hammer(im trying to replace my outer joint on Passenger side)
Old 04-11-2013, 10:08 PM   #18
To pull the hub off the axle I removed:
1. Tie rod end
2. Ball Joint
3. Stabilizer link (the strut support rod)
With those disconnected I was able to easy yank the hub off the outer spline. Then you just have to deal with popping the inner spline out.
