Old 04-11-2013, 11:40 PM   #1
dstephens1962
Drives: 08 yaris
08 Yaris A/C help
Hello all,
my wife has an 08 yaris with a/c problems and before i replace the compressor i want to make sure its the problem.
A/C blows hot air
Compressor kicks on the clutch is working
the low side has hi psi 70ish or around that while running.
any help would be greatly appreciated.
dstephens1962 is offline   Reply With Quote
Old 04-11-2013, 11:50 PM   #2
70 psi is a bit high on the low side, but probably OK. Do you have a gauge set to measure the high side as well? If not, what do you see in the sight glass on the high pressure line with the AC running, and then right when you shut the AC off?
Old 04-11-2013, 11:52 PM   #3
dstephens1962
Drives: 08 yaris
I will have to check when i get home. Should be sunday i will be able to tell you. I do not have a set of gauges but i will be able to get some.
Persuade me to buy a Yaris! TONIZZLE General Yaris / Vitz Discussion 48 09-09-2011 12:31 PM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 12:03 PM
