Old 04-20-2013, 10:06 AM   #73
yariSB86
yariSB86's Avatar
Drives: 07 Bayou Blue Yaris LB
so I don't have to tap the block?
yariSB86 is offline   Reply With Quote
Old 04-20-2013, 11:19 AM   #74
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Here is a photo and yes I flipped it upside down to make it easier orientation-wise...haha
I thought we have been over this already? You are not tapping the block. It is the Upper Oil Pan Sub-assembly.
You will want to tap the upper pan to prevent possible smoking in the future.
Old 04-20-2013, 03:46 PM   #75
yariSB86
yariSB86's Avatar
Yes, I understand where the tap goes. Just seems like getting couple different answers about this.
I bought a small angle drill, tap set, some jbweld, silicone sealant, loctite, Teflon paste, and the fittings I am going I use. (Not sure what sealant is better)
Already have the hose(came with the zage kit) and clamps.
Now when I drill this hole, I'm going 1/2", what is the best way of making sure there are no metal shavings in my oil resevoir? Pour my used oil in and let it drain (do that a couple times)?
Old 04-20-2013, 04:23 PM   #76
I don't give a hoot what people call it. Pan, or block, makes no difference -- you will drill a hole and install a fitting. You can reach it easily from underneath with the pan off.
You'll have the pan off, so I don't understand this question, sorry.
Old 04-20-2013, 04:23 PM   #77
TOLMACH
Drives: soarer
is zage oikl pan so bad? some people seem to be using thouse without issues
Old 04-20-2013, 04:25 PM   #78
^ You just have to be careful not to have a low spot or a kink in your return line. You are correct, the Zage pan is being used by some customers. I'd say it's about 50/50 from the kits we've sold.
Old 04-20-2013, 07:55 PM   #79
yariSB86
yariSB86's Avatar
Sorry Garm, I totally spaced about taking off the pan...hah
Old 04-21-2013, 11:01 AM   #80
yariSB86
yariSB86's Avatar
Ok, think I finally got all the right parts for this oil return install. Going to start with removing the oil pan :) (thanks Garm). Then prep the drill, make sure I have room. Then drill the hole. Wish me luck.
Old 04-21-2013, 01:49 PM   #81
good luck. It's aluminum, pretty soft, just be patient and you'll be fine!
Old 04-25-2013, 08:50 PM   #82
yariSB86
yariSB86's Avatar
Hey guys. Sorry for no updates as I've been sick, and still am. Damn sinus infection.
Anyways, I've managed to get the oil return line finished. Waiting on the oil pan seal to cure. Double checked all my piping/couplers. Pretty close to first start up, won't be until Monday or Tuesday. I'm working all weekend. It's coming along. Slow and steady.
Old 04-27-2013, 03:10 PM   #83
yariSB86
yariSB86's Avatar
I am in need of a base tune I can work off of. The car doesn't idle long enough for me to do anything. Does anyone have anything I can work with?
Old 04-30-2013, 02:52 PM   #84
yariSB86
yariSB86's Avatar
Update #1
So an update for how things have been.
Everything is installed and working as well as it can be for first start up.
No leaking oil, no exhaust leaks.
I need to pick up some heat shroud still. There is a really good place up the street that specializes in this so that's good.
I am having problems though. As I expected.
Only really big problem at the moment is that I need a good base tune to work with. The car doesn't idle long enough (maybe 20 seconds) for me to manipulate anything.
So I am going to ask anyone if they have a good base tune I can work with to just get things going.
Thanks
Old 04-30-2013, 03:00 PM   #85
kou
Drives: 08 lb
Are you using the aem fic? it should start and idle fine,did you install fic before turbo install or all at the same time?
Old 04-30-2013, 03:15 PM   #86
SB86, I'm emailing you a couple of base maps now.
Old 04-30-2013, 03:18 PM   #87
kou
Drives: 08 lb
Send them to me also please to see if what I have made so far is going to work.
Old 04-30-2013, 03:20 PM   #88
yariSB86
yariSB86's Avatar
@kou I am using the AEM FIC. And I did install everything at same time.
@Garm Thank you :)
Old 04-30-2013, 03:25 PM   #89
kou
Drives: 08 lb
Did you calibrate the fic? i am running all zeroed in all the maps and 810us for injector response time I am running NA to collect factory data for maf clamp and afr ratio voltages. Getting my downpipe made on sunday so should have some tuning info then.
Old 04-30-2013, 04:12 PM   #90
yariSB86
yariSB86's Avatar
Garm, that richened tune runs good. I like the 11-10 range for 8psi. Car still doesn't idle. dies almost as quick as I can shift. Like ive I push the clutch in, the car will idle to stall. I don't get it...any suggestions?
also, when i uploaded that tune, my tachometer stopped working...
List of Boosted Yarisworld Members - Redux CTScott Forced Induction Forum 40 06-29-2025 08:42 PM
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 05:49 AM
Boosted Yaris Quarter Mile Times 1.5 Forced Induction Forum 0 01-03-2010 05:49 PM
Going Boosted FryGuy Forced Induction Forum 53 03-01-2009 10:01 PM
PE Boosted Yaris Video jinxor Forced Induction Forum 16 02-06-2009 02:33 AM
