#19 | ||||
YRS WHOR
Drives: White 2007 Yaris E-Limited 5dr Join Date: Feb 2007
![]() Quote:
Image1.jpg Image2.jpg Image3.jpg Good advice, thanks! |
#20 | |
![]() ![]() Drives: 2006 Toyota Yaris RS Join Date: Feb 2007
#21 | |
![]() ![]() ![]() Drives: 03 Toyota Corolla S modded, Join Date: Jan 2007
Well... its an old honda civic "93" my buddy used to own... well I sprayed that "solder seal" engine degreaser when he came to my place and ask me to wash it bcoz his going for a group meet, so I hustled and sprayed it with E.D. and about 3 seconds after I sprayed it, nasty smelling smoke came out... then I hit the freakin header! and it went to flames! quickly he grabbed his "NOS lookin" fire extinguisher and sprayed the hell out of it! the engine lining he installed got melted a bit and he told me to just stop it... and he just went to the club meet with a nasty lookin engine with a burnt hood padding... what I'm saying is some cars need the engine cold just to clean it safely...
THE YARIS: TINY BUT PRICEY! BUT YOU JUST GOTTA LOVE IT....
#22 |
Why degrease an engine that isn't greasy? As a note, those degreasers are powerful, so be careful not to get them into parts with bearings (ie. the alternator pully, A/C compressor pully)...
I just use low pressure water every time I wash the car and my cars stay nice and clean under the hood. Yes, I'm careful where I spray. I would only clean under the hood by this method if I were tring to sell the car. Your pictures look great! |
#23 |
YRS WHOR
Good question, and a simple answer really - obviously to break down any new grime that's on the engine, but also to remove the previous application of dressing/protectant, so you're working with an absolutely clean surface.
It's a little of a catch 22, but it works great
#24 |
YRS WHOR
#25 | |
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
#26 |
Lil White her name is ~
Drives: White YRX 5DR Hatchback 2006 Join Date: Dec 2006
I want to do this with my friend's Camry Sportivo 2003 ~ Is it ok to the the exact same thing ~
Damn the water restrictions here ~ I will have to take it to a commercial car wash with the sprays ~ Yes, I will make sure it's on low pressure ~ About watching out for the belts and others.....how do I "look" out for them or know if I'm getting them sprayed or not ~ I will be doing this to my Yaris too ^_^ ~ Though one person can not drive two cars so I will have to take it to the commercial car wash separately ~ I DON'T LIKE WATER RESTRICTIONS ~ Jaspie ~ |
#27 |
YRS WHOR
The Camry will be fine as well.
As for the belts, it's simple - look at them, understand where they are, then don't spray any dressing/protectant on them :) The engine cleaner and the water don't pose a problem for your belts. Are you allowed to use a watering can with the water restrictions, or are all forms of car washing prohibited? If a watering can can be used, that'll probably do the job - you're really only rinsing off the engine cleaner. |
#28 | |
#29 | |
Thanks for the help ^_^ ~ Jaspie ~ |
#30 |
YRS WHOR
car plate? 'sif you'd go to the trouble of letting speed cameras get a good shot of your car if you're not allowed to wash the rest of it :P
#31 |
#32 |
![]() ![]() ![]() Drives: '00 Toyota Celica GTS Turbo Join Date: Aug 2006
Sweet! Is that the stock engine cover or did you add stickers to the VVTI part to make it red?
#33 |
#34 |
YRS WHOR
Red was standard on mine..
#35 |
yup, for some reason it looks like all 1NZ engine covers have some red VVT-i lettering over here...
The red color alone must bring the engine's power up a few horsepower!
#36 |
YRS WHOR
Well actually I've seen the Thai market Yaris rated at 109HP, while the North American Yaris is rated at 107HP, so there might be some truth in that.. or maybe someone just made an error in the conversion from kW
