Rods and Piston Question
I have cp piston and wanted to know.. what side does those little eye brows on top should be facing. The exhaust side or intake side. The same question for the Bearing Tangs.
Help
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
isn't the intake valve larger than the exhaust meaning that it stands the highest chance of kissing the pistons, so I would assume that they should be on the intake side unless for some reason toyota makes their exhaust valves receive more open than the intake, but normally speaking it would be the intake side.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
Yea i am not too sure I might have to pull out the manual...If I can remember where I put the darn thing.
Ok so for the Pistons they face on the Intake side. No info on the Bearing Tangs tho.
should be a dot, arrow, or something designating the direction to aim the piston to the front of the engine.
Looks like the exhaust side in the Toyota manual.
Thx it is the exhaust side for the Tangs. Time to slap this thing together.
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
^ Good luck, bro!
Pics are highly welcome |
Bearing Tangs face to the exhaust side
piston to valve relieves face to the intake side
05 Scion tC allmotor 350+ hp 9.34@144mph 05 Scion tC sfwd 880hp 9.96@147mph 05 Scion xB 280hp 12.97@104mph 07 Toyota Yaris 357hp 12.80@107mph |
| Forged Pistons, connecting rods, piston rings etcetc | mastaofdisasta | Performance Modifications | 2 | 04-18-2010 12:05 PM |
| Cp Pistons, Pauter rods , greddy, fidanza and other for 1NZ-FE!!! | Giupo | Items for Sale by private party | 11 | 08-25-2009 02:57 PM |
