![]() Drives: 2007 Yaris 3door white Join Date: Apr 2013
Parking on an incline?
I'm parking car everyday on an incline steep because i have where else (in my area).
Each time i go from P to reverse there is that 'thud' we always here when it disengages from a hill or steep. Is constantly doing this damaging to the car? ![]() THanks guys |
When you park try setting your parking brake before you release the brake pedal and putting the vehicle into park. And vise versa when removing the vehicle from park to reverse dont remove the parking brake until it engages the gear. Whats happening the slight momentum when you shift it like that puts a slight strain on your motor mounts. Its similar to when some people are backing up but put it into drive before its come to a complete stop.
Thanks yaris
what will i do without you guys
![]() ![]() Drives: Yaris Sedan Join Date: Apr 2012
Personally, I when I park on the driveway, I first put the car into neutral, release the brake to set the car, then shift to park. Also ensures that you have set the parking lever high enough.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
Yep, our driveway has an incline to it and I always set the parking brake and let the car "settle" before shifting into park (P).
I can usually roll out of it without using reverse. Sometimes I actually move the car out into the street (so I can get my Jeep out of the garage) without even starting it! That said, I can't get the wife to do the same with our Honda minivan. I hate getting in it, shifting to drive and hearing that gawd-awful "THUNK!"
| Parking Light Flash Output vs Hazard Light Output | sex | DIY / Maintenance / Service | 2 | 11-03-2009 08:47 PM |
| 194 Parking Light Harness / Socket | bigsky2 | Cosmetic Modifications (Exterior/Interior) | 13 | 08-14-2009 02:04 AM |
| I dropped something down in my parking brake slot... | Boonespeed | Cosmetic Modifications (Exterior/Interior) | 12 | 08-11-2009 09:31 PM |
| DIY For radios that require attaching a wire to parking brake | Slick | DIY / Maintenance / Service | 0 | 04-16-2009 08:14 PM |
| Parking an Automatic on an Incline | MadMax | General Yaris / Vitz Discussion | 6 | 02-27-2009 07:38 AM |
