Old 04-24-2013, 04:53 PM   #1
BT91
BT91's Avatar
Drives: 2008 Yaris Sedan
Looking to paint Interior panels
Hi everyone. I was planning on painting some interior panels in my yaris sedan. I have seen many threads on finished products and how to do the painting but i have yet to stumble upon a thread that explains how to remove the panels. I was just wondering if some one had pictures or a video explaining how to do this. I am mainly looking to paint the center console and side trim pieces around the pod panel. Might also do the instrusment panel not 100% sure about that one though. I have found a youtube video but the picture quality was crap and no auido, it seemed that he just ripped the panels off. This doesnt seem correct to me, cus I would probably end up breaking the mounting tabs. Any pointers pictures or videos would be greatly appreciated.
Also some sugguestions of colour and what paints to use would be great. My sedan is Pacific Blue Metallic. So any good contrasts would be good. Not looking to have same colour matched pannels.
Thanks
Droppin Gears
BT91 is offline   Reply With Quote
Old 04-24-2013, 06:57 PM   #2
Kar98
Drives: 2011 Scion tC
No, seriously, that's how you disassemble them. You rip them off. Gently. Start with the black long ones, at the bottom, work your way up, and then the rest becomes apparent.
Check the audio sub-forums, there are detailed descriptions.
Old 04-24-2013, 07:03 PM   #3
YarisSedan
Drives: 08 Yaris Sedan
On the sedan door panels its pretty simple. There is one black screw that is located at the door handle removed that with a phillips screwdriver, the window switch assembly has one screw and it literally just pops out. By the mirror remove the black triangle piece and you will see a black plastic clip. Once you remove that grab the door firmly at the bottom and pull and the entire door will come off.
Old 04-24-2013, 08:31 PM   #4
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
If you want to look at the manual, head over to MicroImageOnline.com and you can view where all the tabs and few screws are. But you basically gently rip them off, there are very few screws.
Colin Chapman disciple
Old 04-24-2013, 11:12 PM   #5
BT91
BT91's Avatar
Where exactly is this manual located on micro image? Just been browesing and i cant find or maybe im looking in the wrong place.
Droppin Gears
Old 04-25-2013, 05:28 AM   #6
MyzticZ3r0
Isn't the center console and the instrumental panel the same? Or are you talking about the door panels? Anyways, here's a link for a video - it's not great quality, but that is how you do it.
Link.
To prep the panels, here is a written little summary.
Written Summary
If you're referring to the door panels, here. It's a guide through photos how to remove the doors and window crank.
As to the recommendation on what color, honestly, go with one of your favorites. I found an awesome metallic blue that I used to spray paint mine, along with my cylinder head. The color of my car, however, is meteorite blue. Browse through the link I gave you to help you get ideas.. =]
Thanks
MyzticZ3r0 is offline   Reply With Quote
Old 04-25-2013, 10:49 PM   #7
BT91
BT91's Avatar
So I got the panels all out. The only thing that took a few trys was removing the knobs from the panel it self, but no broken tabs so im happy. Got them all sanded and primed. I bought a few different colours cus I wasn't sure what exact colour I wanted. So I shot it with some red semi gloss. Gonna test fit it in before I finish them to see if I like it, if not going to white or flat balck. Wasnt sure how the red would go with the car being bayou blue. I'll get a pic pic up tommorrow when I check it out. Thanks for all the info guys, you have been quite helpful.
Droppin Gears
center console, customize, paint, panel removal
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
Stripping Paint Without Sanding CrystalJean DIY / Maintenance / Service 1 10-06-2012 04:06 PM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
Buyer Beware: Huge paint defect on brand new Yaris voodoo22 General Yaris / Vitz Discussion 31 07-30-2007 08:24 PM
