Old 05-09-2013, 06:59 PM   #1
TOLMACH
Drives: soarer
Anyone using Boost controllers with ZAGe?
I've noticed a bunch of electronic type boost controllers on e-bay.. Some claim your boost gets more controllable. Some boost gagues even offer that option.
Anyone has any any experience?
Thanks
Old 05-09-2013, 07:16 PM   #2
TOLMACH
Drives: soarer
As one of the examples http://www.aemelectronics.com/tru-bo...ller-gauge-757
Old 05-09-2013, 07:51 PM   #3
kou
Drives: 08 lb
I plan on making a manual boost controller to up my boost
Old 05-09-2013, 07:52 PM   #4
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Not that I have heard. Only if you want to run more boost would I consider it.
Old 05-09-2013, 08:03 PM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I have a manual boost controller on my setup however it is a custom install and not Zage. Some electronic ones can even control your boost by RPM so I am assuming they can have a map like fuel, etc however not sure.
Old 05-09-2013, 09:06 PM   #6
Focus_Sh1ft
Focus_Sh1ft's Avatar
I'm using a tru-boost and have it dialed in for about 9 psi. Very simple to use.
Even if you're only boosting on wastegate spring pressure, you should run an electronic boost controller regardless. You WILL see faster spool up times. Manual boost controllers don't have that benefit though.
Old 05-09-2013, 11:52 PM   #7
fnkngrv
fnkngrv's Avatar
On this I would have to disagree. Perhaps it is my lack of success with the aftermarket electronic regulated devices, but personally I wouldn't trust more of it to possibly take your motor to bad places unless you had a high quality device....and when I say a high quality device I am talking about stand alone management ones or else ones that have tech/parts that are directly used as the basis for the functionality in a solid stand alone ECU. I suppose that you could possibly say the same about a manual controller however they have less likelihood of failure.
Old 05-10-2013, 02:39 PM   #8
TOLMACH
Drives: soarer
With your tru boost - you can control the spooling time (faster).. is there a way to avoid overboosting?
Old 05-10-2013, 02:42 PM   #9
It's the controller's job to avoid overboosting. That's one main reason to have a controller.
Old 05-10-2013, 02:52 PM   #10
I can't tell what you are disagreeing with. He makes three statements there to pick from.
True, and it doesn't matter if it's a dedicated controller or part of a standalone. Both require a solenoid to operate the wastegate.
True. More power sooner. You might also get more control options (hard vs. soft ramping) etc. depending on the brand of controller or standalone parameters. (I loved the World Racing controllers). Also available might be boost by gear, boost by rpm, etc.
Manual is "set it and forget it" -- very few features, I'm just not a fan.
Old 05-10-2013, 04:07 PM   #11
Focus_Sh1ft
You simply can't go wrong with an electronic boost controller. Even if the solenoid failed, it's very unlikely you'd overboost (it would have to get stuck in the 'on' position). You'd be right back to running on spring pressure.
FS: Zage Turbo kit, AEM FIC with Pnp Harness djgab101 Items for Sale by private party 32 04-11-2013 11:42 AM
Stock/Built Motor - Boost and Durability Yoda Forced Induction Forum 74 03-21-2012 02:18 PM
Zage turbo kit Mister Z Forced Induction Forum 17 11-26-2010 04:32 AM
Multiple cylinder misfire under boost LtNoogie Forced Induction Forum 13 11-02-2009 05:44 AM
