Old 05-20-2013, 01:46 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
Anyone know of a small digital coolant temp gauge that will fit in a single din under
I was looking to fit a digital water temp gauge and volt meter under my stereo in the single din location. Was going to fiber glass over and make custom cutouts for the gauges. Something like this
Although the display looks a bit big im looking for something a little smaller
Old 05-20-2013, 02:57 PM   #2
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
look on ebay for smaller, there are a bunch of these people are selling.
caineroad is offline   Reply With Quote
Old 05-20-2013, 04:01 PM   #3
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
why not use a scangauge 2? I think it would fit in that slot easily and you can decide from many parameters.
Be the change you wish to see in the world -Mahatma Gandhi-
BEEF is offline   Reply With Quote
Old 05-20-2013, 04:11 PM   #4
jayeh
Drives: '08 Yaris LB
I was going to say this too!
jayeh is offline   Reply With Quote
Old 05-20-2013, 05:08 PM   #5
YarisSedan
Mainly because i have a eco meter hooked up and sitting behind my steering wheel i like to use it for a rpm and mph gauge sometimes but scangauge is a good idea i dont know why i didnt think of that. I might compromise and just use a scan gauge i think it would fit perfectly for my application.
Old 05-20-2013, 05:21 PM   #6
BEEF
BEEF's Avatar
you can get an obd2 Y adapter and use both... you may want to check on current draw but I think you can do it. I know a few people that have daisy chained two scangauge 2s together.
Old 05-21-2013, 11:49 AM   #7
^ You can definitely chain 2 Scangauges together. The ports are built in and I think I have the cable for that.
Old 05-21-2013, 12:38 PM   #8
YarisSedan
You guys are right quick search on amazon i found this. I think i will get both now. http://www.amazon.com/automotive/dp/B000TMCX72
Old 05-21-2013, 02:04 PM   #9
BEEF
BEEF's Avatar
I think with two scangauges all you need is some CAT5 cable and ends. (linear logic sells such cables but at a premium)
he is trying to have is ecometer and a scangauge. I have heard the ecometer draws more current but that means very little without numbers and I haven't really looked it up.
Old 05-21-2013, 07:36 PM   #10
screenprintr
screenprintr's Avatar
Drives: 2010 Toyota Yaris
Now days you can buy the cat5 ends that are self crimping. I still have my crimper.
screenprintr is offline   Reply With Quote
Single DIN Digital Gauge Cluster Galavoxx Performance Modifications 11 12-29-2006 04:09 PM
