Old 02-17-2013, 11:05 PM   #271
33OH
Drives: '08 Yaris
Joao, how wide are the wheels? If they are 16x7's, you won't have any issues at all with that offset and tire size.
Old 02-18-2013, 06:43 PM   #272
JoćoMendes
Drives: Toyota Yaris D4-D
Thanks for the quick response 33OH.
Yes, they are 16x7''. Another doubt..my yaris is a diesel engine, a 1.4cc 90hp, will it run 17x7'' ET 40 with 205/45..or it will be to much ?
Thanks a lot!
JoćoMendes is offline   Reply With Quote
Old 02-18-2013, 07:10 PM   #273
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
16x7 is probably pushing it weight wise, but at least you will have the torque of the diesel to help.
Colin Chapman disciple
Old 02-19-2013, 05:27 PM   #274
LOKink
Drives: 2007 3dr Lift Back
I have an 07 Hatch lowered with springs, I am looking at putting on 17x7 Sparco Asetto Gara with 195/40/17 will I have any problems with rubbing or anything?
LOKink is offline   Reply With Quote
Old 02-19-2013, 05:40 PM   #275
vten
I'm running similar setup , with +37 offset . No rub at all ..... But after I added a 10mm spacer on the rear, it rub a little on a large dip .
Old 02-19-2013, 05:53 PM   #276
LOKink
thank you! wheels and tires ordered.
Old 02-27-2013, 01:51 PM   #277
tommih
Drives: Soon Yaris XP13
Yaris 1,33 2013 with lowered springs, do you guys think that ET 35 will rub?
195/50/16/7
Anyone ? Greatful for answers =)
tommih is offline   Reply With Quote
Old 03-21-2013, 11:39 AM   #278
JoćoMendes
Hi mates..I have a 5 door hatchback..I am wondering to lower it like 1.2 inches..1.4 inch maximum. Will the mini cooper 17x7 et 48 wheel rub with 205/45 tire?
Thanks for the help one more time :)
Old 04-23-2013, 10:23 AM   #279
Mikkelsen_7
Drives: ToyotaYaris Hybrid H2
Hello, i hope there is someone who can help me,
i am trying to figure this out..
I have a:
Toyota Yaris Hybrid.
right now i am driving on 15" standard weels and 175/65/r15 tires...
I want to go to 16" MAK Iguan Matt White.
(195/50r16 tirers)
But i dont know about the ET and the others thing...
I dont now what my 15" are in ET.....
What i can read, this might be the right one for 16"?
16" x 6 mm x4x100 mm ET43 57 mm
(thats the MAK Iguan)
Would these work?
Regards
Peter
Mikkelsen_7 is offline   Reply With Quote
Old 04-23-2013, 11:06 AM   #280
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
16x6" ET43.
pcd 4x100
It will work.
16x7" would be ideal.
But the MAK Website says "not available". You may have to contact them first.
Old 04-23-2013, 12:12 PM   #281
Mikkelsen_7
why would a wider rim, be better on a hybrid? ... then you got a bigger surface, that uses more BHP ?
Old 06-02-2013, 11:04 PM   #282
mario98c
mario98c's Avatar
15x7" +30 offset 205/50/15 tires. Will it rub?
Old 09-17-2013, 02:07 AM   #283
jdmrye
Drives: Vios
16x7 et42 205/50 will they rub if i drop 1 inch all around?
thanks in advance
jdmrye is offline   Reply With Quote
Old 09-18-2013, 12:58 PM   #284
33OH
Drives: '08 Yaris
Likely to have minor rubbing there - it will be close and depend on your drop.
thanks in advance
You'll be fine.
Old 09-18-2013, 03:45 PM   #285
speedysilver
Drives: pocket rocket
help
help choosing tires for two different sets. My car 3dr hatch would be lowered more +1
15x7 +32 looking at 195/50
16x7 +35 looking at 205/40
thank you in advance
speedysilver is offline   Reply With Quote
Old 09-18-2013, 03:53 PM   #286
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
what do you mean help? I dont see a question?
Are you asking which of those two you should go with? That would be a personal preference. If you like the way 15s look go with that, if you like the way 16s look go with that. I would not go wider than 195 on a 7, not saying you CANT go wider, that is only my preference
Old 09-18-2013, 04:08 PM   #287
Those tire sizes are too short. 50 series should be on 16s and 40 series should be on 17s.
Old 09-18-2013, 04:12 PM   #288
speedysilver
Sorry to clarify...I would like to know what size tires would fit best on a lowered yaris considering the wheel specs I posted?
so you're saying 50 series on both?
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
