Old 06-02-2013, 11:29 PM   #1
BennyLava
Drives: 1987 Silverado
I'll ask again: How to mount license plate securely with no holes?
How can I mount my front plate to my 2009 toyota yaris without making new holes in the front bumper? It currently has no holes and I really don't want to make any. On top of that, I really didn't see any way to mount the plate on the bumper cover, that was actually secure. Just screwing into that weak plastic isn't going to last long. Been there, done that, on other cars. It always eventually falls off.
So where the heck do you mount the plate securely? There must be somewhere. Someone linked a tow hook mount last time, but I really don't want to use that. Plus it was $70 and that's a bit too much for a freakin' license plate bracket. Is there no simple, cheap, easy way to do this? If not, then screw you, Toyota!
BennyLava is offline
Old 06-03-2013, 12:16 AM   #2
Screwing the plate to the front bumper really is not a problem. Both of my roadable ones have front plates and they are both on there securely. When I picked up my brand new 2009 from the dealer, the sales person mounted my new plates right in front of me.
The key is using large coarse thread screws (#10 or #12 screws) and not over torquing them, which will strip the plastic. If you are really concerned about not using fasteners into the plastic you could use 3M emblem adhesive or one of their automotive trim tapes to attach it to the bumper.
CTScott is offline
Old 06-03-2013, 07:19 AM   #3
BennyLava
I dont wanna! My bumper has no holes! I hate to put some in there at this point. Does anyone at least have a professional looking bracket?
Old 06-03-2013, 07:47 AM   #4
nookandcrannycar
You could try 3M Scotch Dual Lock Reclosable Fastners - 1 inch x 3 inches. I use them on my dash and they are rock solid after almost 5 years of Humid Subtropical heat. I had the same 'model' on another car for 5 years prior to getting my Yaris. I've nver tried using them on the outside of a vehicle, but they've never left any residue when taking them off re no longer using the equipment they were holding....so I'd probably test one in an inconspicuous place on the exterior. Last time I checked, radio Shack still carried them and IIRC they were $3.99 USD for 4 of the 1x3 strips. They come in at least Black and also clear. I've always used the clear ones.
nookandcrannycar is offline
Old 06-03-2013, 10:15 AM   #5
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
If you don't want to drill holes why not just not have a front plate?
47_MasoN_47 is offline
Old 06-03-2013, 10:34 AM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Many states require it now. I have even been harassed which driving those states when I didn't have mine on. Maine requires a front plate and so does Customs when you cross or at least they will give you plenty of crap about it if you don't have it on in my experience.
fnkngrv is offline
Old 06-03-2013, 10:38 AM   #7
fnkngrv
fnkngrv's Avatar
This would be your only solid option then:
http://shop.microimageonline.com/Tow...?categoryId=-1
Using the 3M tape is a novel idea, but in the high heat that you will most likely encounter there in TX I am not really thinking that it will stay for long especially with the turbulence of driving and exposure to moisture. I tried that route myself with my Army Veteran plate. Was not successful. It fell off, but at least it did it in my driveway. It is what it is.
fnkngrv is offline
Old 06-03-2013, 10:43 AM   #8
BennyLava
They're all garbage, more government intrusion into our life. Normally I don't run one just to spite them and local cops don't even care. But the wife keeps getting bothered by Barney Fife on the way to work 1 small town over. They got nothing better to do it seems.
Well if I do end up having to drill holes, is there at least a professional looking one? One of those black ones that the plate rests in. Typically, they look like they sort of mold to the bumper cover itself. As if they are part of it. And usually are made out of black plastic.
Old 06-03-2013, 11:46 AM   #9
47_MasoN_47
Jeez. AL is apparently one of the few free states left where every aspect of vehicle ownership isn't regulated in every fathomable freaking way.
Lol, regulating where you put license plates. wtf.
Old 06-03-2013, 12:41 PM   #10
RedRide
RedRide's Avatar
I have to admit that I'm a bit confused. Why would you not want to fasten the plate with a couple of screws whenever it it required by law to have one? Your rear plate is screwed on...... correct?
When front plate is also required, screw one on.
Is it a DD or, some very expensive dedicated show car?
I can not understand all the aversion to a front plate as most industrialized countries and most states require one as it does not make sense to have one only in the rear .
"State's rights"? Give me a break.
FWIW.....My '09 HB came from the dealer with a proprietary black plastic front license plate bracket and IMO looks very nice.
RedRide is offline
Old 06-03-2013, 01:06 PM   #11
sex
sex's Avatar
Drives: 09 5DR
How about making a bracket which attaches to the bottom bolts of the bumper? Might not work if you have a lip though
sex is offline
Old 06-03-2013, 01:27 PM   #12
Like Adrian said, no holes with this:
cali yaris is offline
Old 06-03-2013, 01:35 PM   #13
bankrobber
Drives: 2007 Yaris Hatchback
move to Florida. No front plate required
bankrobber is offline
Old 06-03-2013, 01:37 PM   #14
47_MasoN_47
Because it's stupid. There's already a plate on the back, why do you need one on the front? If you start making the big bucks one day and buy a nice Lambo are you going to be all excited to take a powerdrill to that mufugga because some dickhole politician thinks you need to be identified more easily?
Most industrialized countries don't have gun rights either, and all of those guys can kiss my M-11's ejection port.
Old 06-03-2013, 04:44 PM   #15
RedRide
RedRide's Avatar
WTF do gun rights have to do with it? Please keep your politics out of this thread.
FYI, cops frequently need to see a criminal's license plate when they are coming towards them, not just when following them
Now, I'm all for a state's right not to to require a front plate, So what is your complaint ? It just annoys me when people scream "state's rights" without a logical reason for it.
Do you just want to scream "State's rights"as some sort of battle cry or what"?
I would suspect (hope) that if you ever did get rich enough to buy a Lambo that you would be a bit more mature by then .
RedRide is offline
Old 06-03-2013, 05:02 PM   #16
47_MasoN_47
lol you're the one that brought up the state's rights thing. Noone else ever even mentioned that.
I brought up gun rights simply because the whole "most $x do $y" isn't a valid argument for actually doing something.
Old 06-03-2013, 05:15 PM   #17
UberSilver
UberSilver's Avatar
Velcro will work.
http://www.globalindustrial.com/p/pa...FSeCQgodERUAsw
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
UberSilver is offline
Old 06-03-2013, 05:15 PM   #18
Astroman
Modded Moderator
Astroman's Avatar
Actually Mason, fnkngrv did in post #6. Regardless, poor comparison.
Astroman is offline
License plate bracket for '09 that doesn't require putting holes in the bumper? BennyLava General Yaris / Vitz Discussion 16 03-10-2013 04:08 AM
LED License Plate Frame chrisj Cosmetic Modifications (Exterior/Interior) 7 09-22-2010 12:21 PM
WTB: Front License Plate Mount and OEM wheels/tires Snarf77 Willing to Buy by private party 3 07-23-2009 01:43 PM
DIY Camera Mount -- No Cost Version KCALB SIRAY DIY / Maintenance / Service 20 06-08-2009 04:12 PM
How can I cover front license plate hole hans_fh General Yaris / Vitz Discussion 13 01-03-2007 01:58 PM
