Old 06-01-2013, 09:56 AM   #19
soup1207
Drives: Yaris 2009 automatic
I read the following
http://www.ehow.com/info_8594854_hap...-bearings.html
The noise doesn't happen on sharp turn, and only happen when speed reach about 70....if it fails, shouldn't it happen whenever my speed is increasing?
I am going to have a drive today to checking it since I did the tire rotation few days ago and my brother said he didn't hear anything the day after.
By the way, one of my tire lost its cover....would it be a reason to create noise due to ...wind?
soup1207 is offline   Reply With Quote
Old 06-01-2013, 11:27 AM   #20
Septembersrain
♣♀Yaris'ing♀♣
Septembersrain's Avatar
Drives: 2013 Yaris 3-Door LE ~Pearl~
I do know that it was obvious they were going on my Kia.
When I'd break the steering wheel would shake like crazy and veer to the right.
It always made a slight grinding/crunching type of sound during sharp turns.
Does yours do that?
Don't be a drip. ◄~(¬ _¬)~
Septembersrain is offline   Reply With Quote
Old 06-01-2013, 02:07 PM   #21
soup1207
Does yours do that?
I don't have the symptom you mentioned. I only hear noise when it's getting close to 70.
It's weird as sometimes it disappear..Like today
At first, it "woo wooo.." when close to 70....after a while, it seems worsen, "woo" at about 6x ...
A while later, when I try to speed up again, it disappear....=___=
An update --
I follow some instruction online to jackup my car...then try to shake the wheel to see any noise. It seems normal. (I shake with my hands on the top and bottom of the wheel).
Is it possibly something relate to belt slipping?
Old 06-04-2013, 05:45 PM   #22
soup1207
Today got my car back from a good rating auto repair store (good rating according to yelp.com). They can't hear any noise .. According to them, it shouldn't be a problem os wheel bearing.
Now I can only hope it's some sealing problem like windows.
Keep you guys update for future reference if I figure that out.
Old 06-05-2013, 12:26 PM   #23
esse10
Drives: 2009 yaris 2 door
tires
Some tires will sound like that woo woo woo after a certain uneaven tread wear, espacially after a complete rotation on those same tires. More common in 50-60k miles warranty tires. "been there done that...seen it"
Old 06-12-2013, 11:55 AM   #24
soup1207
I really hopes it's the tire causing the problem. That means changing the tire in the end of summer should fix it.
The auto repair store failed to hear the noise....but like I said, it sometimes disappear and it may also disappear after 70 mph. I am so lost about it. Now I can only rely on the auto technician who claiming that he cannot hear any noise.
Old 06-12-2013, 11:59 AM   #25
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I'm leaning towards tires as well.
-Type 07 FFL-
My odometer 03/11
Compilation of Yaris TSBs eTiMaGo DIY / Maintenance / Service 72 07-04-2024 10:36 AM
metallic noise when accelerating poida DIY / Maintenance / Service 3 03-29-2015 12:20 AM
squeaking noise after starting car caineroad General Yaris / Vitz Discussion 7 07-17-2012 09:15 PM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 12:27 PM
Squeaking Sound underneath 2008 Toyota Yaris Sedan Automatic SDYarisGuy DIY / Maintenance / Service 3 02-27-2011 05:36 AM
